Low hyd fluid Jinma 254
/ Low hyd fluid Jinma 254 #21
Glad you got it back up and running Ray,let us know if you need anything else
Tommy
Affordable Tractor Sales
/ Low hyd fluid Jinma 254 #22
Tommy/Ronald,
So was this a manufactering problem covered by warranty or just a failure? Would you expect that others with tractors made around the same time to have this problem as well?
Thanks,
HT
/ Low hyd fluid Jinma 254 #23
It is not a warranty issue,it could have been the pump dead headed for one reason or another,pump loose,who knows.I have seen it happen on a few tractors ,but not a common problem
Tommy
/ Low hyd fluid Jinma 254 #24
half_ton said:
Tommy/Ronald,
Thanks,
HT
I don't see any warranty coming out of China/Jinma on this. I don't think this happens a lot verses how many Y385's are out there. For me the drive gear is a very slow moving part number.
It's hard to go into/over every step and inspection procedure when replacing a pump. But in general one should try and take note to proper fit/alignment/contact etc...... try not to assume and verify.
Like if the pump drive went to far in the slot ..... then you may need two gaskets ??
I have seen similar damage on other engine driven pumps. Sometimes I have been able to see/find/correct and sometimes ... beats the ***** out of me??
Ronald
Ranch Hand Supply
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2022 EZ-GO ELITE...
2004 John Deere 8320 (A63688)
2004 John Deere...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
