Low HP forage harvester
   / Low HP forage harvester #1
Chiriqui
Chiriqui, Panama
none
Anyone got experience with single row, 3pt forage harvesters in the 40-60hp range?
   / Low HP forage harvester #2
We have a 1 row Vicon that we pulled with 95hp, but you were supposed to be able to use it with a 50 to 60 hp tractor. We now use a 2 row and the 1 row is just sitting there. Not much of a market around here for forage harvesters.
Thanks, down the road I may be interested when I figure out what I'm doing.
   / Low HP forage harvester #4
We run a 5' flail type crop chopper behind a 45 hp tractor, mowing grass. I have hauled it with my Farmall H at 26 hp but takes low gear. We use a couple of small feed wagons, if you are hauling large forage wagons or dump wagon it will require more HP as well. Also the flail choppers don't chop as fine but they do mow the crop so it saves a pass. Are you making silage or direct feeding the crop?
I may feed some greenchop, but my intention is to make silage. I would load the forage into the bunker from the wagon. I'm not using a bagger.
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
