low fuel flow on a Kubota L5740 tractor
   / low fuel flow on a Kubota L5740 tractor #1
wcsmith
Hillsboro, Texas
Have a Kubota L5740. I suspect the lift pump is going bad but was wondering...When I disconnect the output side of the lift pump (it is actuated by cam) and then try and start the engine, should there be a good steady stream of diesel coming out the out port of the pump (the line going to the injectors). When I do this, the flow of diesel seems to be irratic, not a regular flow.
I guess I should have added that flow coming from the tank is good. Flow coming out the water separater is good and flow going into the lift pump is good.
   / low fuel flow on a Kubota L5740 tractor #3
I don't think it is a gear pump so the flow will not be steady you should get pulses of fuel due to the design of the pump.
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
Curry Bac Bottle, 4700 gal bottle with pump/vac  (A52384)
Curry Bac Bottle...
toro turf sweeper (A50324)
toro turf sweeper...
