Louisiana Grounds Keeper
/ Louisiana Grounds Keeper #1
wespleasants
Monroe, La
Mahindra 5005 D1
I'm new on this forum. I take care of a little over 22 acres as part of a Bible Institute Campus and am new at driving a Tractor. I have a well used Mahindra 5005 D1 , with a FEL and a BH, that was worked on a long time before I came to be seated upon it. I am learning alot from an older friend who has much experience driving but not exactly a mechanic. I am having a blast learning about what to do and not do. Looking forward to this forum.
He made a ditch and digged it, and has fallen into the ditch which he made.
God
/ Louisiana Grounds Keeper #3
Do you have the manuals? Is so read them and operate the tractor and read them again. If not suggest you see if you can find a set. Some common sense goes a long way with the machine you have. Get in the middle of a field and running about half throttle use the backhoe to learn it and the fronet end loader. You don't drive fast with load on the FEL or it raised. Assume it has both left and right brakes as any tractor I have evern seen does and running down the road and you have one good brake or you only hit one the tractor will sway if not turn that direction. Use both for road driving. Oh the hyd system is running high pressure. DO NOT lossen a fitting with the machine running and if possible be sure you cut it off and operate that circuit to bleed off the pressure when hooking or unhooking any fittings or hoses.
/ Louisiana Grounds Keeper #6
Welcome to the forum from Oklahoma.
Ken
/ Louisiana Grounds Keeper #8
Welcome to TBN from Missouri.:)
Thanks. I have ordered an operator's manual and will read up on this machine. The BH is a John Deere Bush Hog and I've ordered blades for it since the ones on it are more like 2 planks that blades. Having trouble with power steering right now. I refilled the reservoir to no avail. Someone suggested replaced the filter which I am now trying to find where it is. Guess I'll find it when myt manual gets here.
2013 FREIGHTLINER M2 112 S/A 4X2 DAY CAB TRUCK TRACTOR (A59910)
2013 FREIGHTLINER...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2015CATERPILLAR 329FL EXCAVATOR (A62129)
2015CATERPILLAR...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
