LOUD in the cab. Can you hear the radio??
   / LOUD in the cab. Can you hear the radio?? #12
Mine is new and as quiet as any I've ever been in.
   / LOUD in the cab. Can you hear the radio?? #13
Huh? Couldn't hear the question.
My hearing is so shot that cab or not I can't use a radio. Have Bluetooth ear buds for my music and cuts out the tractor noise.
   / LOUD in the cab. Can you hear the radio?? #14
I have a Kubota Grand6060 and forget the radio. For me no issue, not like the radio on when running a piece of equipment. As was pointed out letting the machine talk to me. You may want to see about installing a good rubber mat over the one in the cab to help block sound from the transmission.
   / LOUD in the cab. Can you hear the radio?? #15
Should probably keep radio turned down anyway to listen for issues.
I remember the first time I operated a cab tractor making hay. No radio (I don't think) and a nice JD cab. After a couple of rounds I couldn't stand not hearing all the "intricacies" of all that rotating chit and had to tilt out the back window just to get in touch. 😆
   / LOUD in the cab. Can you hear the radio?? #16
I have 2 Kubota Grand L6060's. Since I got my Apple Airbuds, I wear them almost all the time when I'm in the tractor. I always set them on noise cancelling.
Sometimes I will listen to something from my Iphone, and sometimes I will listen to the radio in the tractor. For some reason, I can still hear the radio without hearing so much tractor noise. I like the way it works for me.
Our old JD 4440 had a fairly quiet cab and had a good radio with cassette deck and CD player that you could hear easily. Plus we had a business band radio that we could hear well and it talked out good too. Where I worked, my last job, we had a Case IH and a Kubota, both about 100hp, that were both fairly quiet. But I agree about wanting to be able to hear what was going on with whatever implement I was running. But on those long nights plowing snow, where I knew the roads and parking lots well, I cranked up the radio.
But this RK37SC is SO loud in the cab that if I had good enough speakers and amp to be able to hear anything above the engine and transmission noise, it would severely damage my hearing in fairly short order. I am going to try to put down some more rubber matting on the floor and look for holes and cracks to plug to see if I can quieten this thing down to a tolerable level.
   / LOUD in the cab. Can you hear the radio?? #18
Timebak, my RK37HC is very noisy too. I gave up on using the radio and bought a pair of noise cancelling bluetooth head phones. Using them and my phone I listen to SirusXM most times. I think they were right at $39 on Amazon. They work great but I wish I would have spent a few dollars more and got the ones with a mic so I could talk on my phone without having to hold it.
   / LOUD in the cab. Can you hear the radio?? #19
One tractor with a cab, two that are open (three if you count the old garden tractor), zero radios. Don't want one, either. I prefer to keep my attention on the task at hand.
As far as I'm concerned, distracted driving is as dangerous in a tractor as it is in a road vehicle - under some conditions more so.
   / LOUD in the cab. Can you hear the radio?? #20
Something that has worked well for me:
I have one of the headsets where it sits on my one ear, leaving the other open for noises. It doesn’t cover my ear, just sits on it. I will occasionally listen to talk radio or a Phillies/Eagles/whatever game while operating.
I can also make phone calls if necessary. It bluetooths to my I-phone. I can leave the cab of the tractor up to about 100’ and still hold a conversation.
I have found this an excellent solution to being able to listen to something, but still be able to hear my machine easily and make a phone call. It’s excellent for safety.
LIGHT TOWER (A56857)
2007 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2007 Vantage...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
2019 Harley Davidson (A56859)
2019 Harley...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
