Lost some oil, is it possible new hoses I put on took it?
   / Lost some oil, is it possible new hoses I put on took it? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So spent the afternoon in a panick, trying to figure out why I am around 6 quarts low in my hyraulics.
Have looked everywhere, dry as a bone. run the tractor up, nothing.
It just dawned on me I built a new stump grinder. It has around 10ft of 3/4" hose. I am thinking this is where it disappeared to but want to make sure you guys concur.
   / Lost some oil, is it possible new hoses I put on took it? #2
Pi X Radius squared. 3.14 x (.375x.375) X120 is 53 cubic inches. Gallon is 231 cubic inches. Check my math and google research.
   / Lost some oil, is it possible new hoses I put on took it? #3
How big was the cylinder and was it empty when you installed it ?
   / Lost some oil, is it possible new hoses I put on took it? #4
Just do a thorough check of your tractor before coming into conclusions. Do not rule out the possibility of a fuel leak.
   / Lost some oil, is it possible new hoses I put on took it? #5
Looks right, so that accounts for 1 out of the 6 missing quarts.
Hmmm. . Oil level has stayed high. No drop. Maybe my level was low before I changed the hoses but 6 is a lot (not for this tank as it holds a 10 gallons at least). Will continue to explore the issue.
   / Lost some oil, is it possible new hoses I put on took it? #7
You are losing fluid somewhere else.
Park it on a clean dry surface and check for leaks after running if for a while.
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55302)
2021 John Deere...
2012 BMW 328i Coupe (A55758)
2012 BMW 328i...
Zero Turn Mower (A55853)
Zero Turn Mower...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
