Lost some oil, is it possible new hoses I put on took it?
   / Lost some oil, is it possible new hoses I put on took it? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So spent the afternoon in a panick, trying to figure out why I am around 6 quarts low in my hyraulics.
Have looked everywhere, dry as a bone. run the tractor up, nothing.
It just dawned on me I built a new stump grinder. It has around 10ft of 3/4" hose. I am thinking this is where it disappeared to but want to make sure you guys concur.
   / Lost some oil, is it possible new hoses I put on took it? #2
Pi X Radius squared. 3.14 x (.375x.375) X120 is 53 cubic inches. Gallon is 231 cubic inches. Check my math and google research.
   / Lost some oil, is it possible new hoses I put on took it? #3
How big was the cylinder and was it empty when you installed it ?
   / Lost some oil, is it possible new hoses I put on took it? #4
Just do a thorough check of your tractor before coming into conclusions. Do not rule out the possibility of a fuel leak.
   / Lost some oil, is it possible new hoses I put on took it? #5
Looks right, so that accounts for 1 out of the 6 missing quarts.
Hmmm. . Oil level has stayed high. No drop. Maybe my level was low before I changed the hoses but 6 is a lot (not for this tank as it holds a 10 gallons at least). Will continue to explore the issue.
   / Lost some oil, is it possible new hoses I put on took it? #7
You are losing fluid somewhere else.
Park it on a clean dry surface and check for leaks after running if for a while.
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Fork...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
