Lost Prime in Iseki Landhope 200
   / Lost Prime in Iseki Landhope 200 #1
maineRedneck
Hi all, I feel like an idiot. Ran it out of fuel. Never have before. Dont know how to prime this thing. 3 cyl., its got a lever on the injection pump. I believe there is fuel to the filter bowl. Any suggestions???
Stranded,
Maine Redneck:eek:
   / Lost Prime in Iseki Landhope 200 #2
I,ve only had to once when I had to replace the fuel line because it ran the fuel out.
I filled the filter bowl , Loosened the incoming line to the pump first till there was fuel coming out & no air. Then the outgoing line. Next the injectors on the moter itself starting with the closest one to the pump . Each time cranking the engine a few times . As soon as the last one was bled it fired right up.
I dont know if this is the correct way or if theres an easier way , But it worked for Me . on Some deisels theres a plug on the pump that can be used to bleed it But I,ve allways did it this way on My big trucks. Best of luck.
Hopefully someone might know an easier way. Bob
BTW , I would suggest changing the fuel element as well. Because its probablly full of any sediment that was in the bottom of the tank.
Thanks Cowboy,
I did replace the fuel filter. I found if you blow in the tank it helps the gravity feed fuel to push out the air faster. Dont drink and Prime!!!
have a great 4th!
Maine Redneck
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
