Lost power to frontend loader and 3pt hitch
   / Lost power to frontend loader and 3pt hitch #11
Trucksales, please keep us posted as you figure out the problem. BTW, I know that my 3 point shouldn't move when my FEL moves...I'm thinking I have an internal leak in my 3 point and the tractor keeps supplying pressure to the three point to keep the implement elevated. Your symptom of having the mower drop suddenly sounded like what I'm seeing. If I understand the systems correctly, neither the three point or FEL should move with a loss of hydraulic pressure until the operator moves the controls to "vent" hydraulic fluid so the implement/loader can move. After all, we can leave our FEL and implement elevated after we stop the engine, right? If your FEL and three point both moved without you touching the controls then I'm wondering if you have a different problem than hydraulic pressure supply. If the three point and FEL both lowered only after you moved the controls, then you're probably right that it's a hydraulic pressure supply problem.
I'm pretty sure the backhoe had never been removed from my L35 before I bought it, which means the three point and pto had never been used/moved either. I'm thinking the three point cylinder or piston/seal is somehow damaged by lack of use. Someday I'll tear it apart and figure out what's wrong. But it works OK now. This will be an early winter project.
   / Lost power to frontend loader and 3pt hitch #12
I had a similar issue with my L35 a few years ago. I don't know how the three point hitch is related as I did not even look there as my Back Hoe has always be connected. I lost power to the FEL and traced it to the front of the drive shaft going to the front pump. It was "fun" taking it all apart as it is below the battery. I found the splines on the adapter going into the pump were shot and most of the splines on the pump itself. As the adapter was about $115.00 and the pump was almost $1000 I opted to just replace the adapter and hope it lasts for awhile. My pump splines were in better shape then the adapter. It has been working OK for a few years now but there is a noise coming from the front so I suspect it will be time for a new pump and adapter in my future. There is no easy way to lube the splines at all without taking it totally apart. Poor design if I was going to say such a thing. Let us know what you find.
2018 FREIGHTLINER M2 26FT BOX TRUCK (A58018)
2018 FREIGHTLINER...
PALLET OF MISC BOAT MOTOR PARTS (A58374)
PALLET OF MISC...
31 FT x 50 FT Heavy Duty Metal Storage Garage (New/Unused) (A59225)
31 FT x 50 FT...
2007 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2007 Vantage...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
