Lost my draw bar
/ Lost my draw bar #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I was out trying to clean out a drainage ditch. I pulled out several rotten logs with a chain on the draw bar. I then hooked up a landscape rake and started pulling out underbrush. I found some more logs, wrapped a chain around them and backed the tractor up to the chain. Went to connect the chain to the tractor and no draw bar. I looked all around the work area but couldn't find it. I think it is in the brush pile. I am in the process of building a soil seperator. I hope I can find the draw bar in the brush pile with the seperator. Just another fun day in the seat.
/ Lost my draw bar #2
Yeah, I hate it when that happens. I removed a pin from my rear blade to allow it to "float", i.e., rotate on it's longitudinal axis, and stored the pin by hanging it in one of the other holes on the impliment. Like a dummy, I hung it with the angled part up and the clip on the bottom and it fell out of the hole after awhile.
Spent several hours hunting in the grass along the path where I used the blade (which was unfortunately about 800 feet long). Even tried using a metal detector, though I thought I would be able to see it since it was a 3/4 inch pin about 6 inches long.
Anyway, I was about to give up about dark, but decided to retrace my path one more time. Then I remembered one area where I had turned the tractor around, but forgot to check all the other times. Sure enough, there it was.
On the plus side, I did find that there is lots of metallic stuff buried along that path that I'll have to go back and check out someday.
/ Lost my draw bar #3
Similar incident happened to me.
I had just bought a large pair of Channel Lock pliers which I kept in an open tool box on the tractor. Paid about 30 bucks for them. Well, while working under some Oaks, a branch must have snagged them and they were lost! I was miffed since they were new, so I bought a pretty good metal detector and ended finding the pliers with it. Of course it cost me 200 bucks for the metal detector, but so what ... it's the principle that counts!:)
/ Lost my draw bar #4
I usually hook up my finish mower and I'll find the lost items right away, usually right after sharpening the blades and greasing every thing up :eek:
I have found chains, receiver hitch & 2.5" ball and a 2.5" pipe & chain :(
heheh
Mark M
/ Lost my draw bar #5
How about a couple of speaker magnets on a chain to drag thru the pile? Just a thought...
David from jax
/ Lost my draw bar #6
Many tool rental places also rent metal detectors. My son lost a brand new backhoe tooth picking ledge. He hand dug for over an hour trying to find it. I found it about 14'' down with a metal detector in less than 2 minutes. MikeD74T
/ Lost my draw bar #7
Did the same after I moved to my new place last year. Problem is I lost it in about 40 acres of weeds and muck soil...never seen from again. I bought a new one (though not as nice) at TSC. My only concern is that someday I "find" the old drawbar with a brush hog blade.....oouch!.
/ Lost my draw bar #8
I have an I-beam for my front bumper. It makes a very convenient place to lay things. I lost a 4 pound hand maul that way....I sure hope I don't find it with the bush hog! :eek:
Last fall I had a large pile of debris that I was working with and a stick knocked my glasses off. It took me about an hour to find them. :mad: I put them back on, and within 30 seconds another branch knocked them off again. Took about 30 minutes to find them the second time. :mad: :mad: :mad: All my wife had to say was that I was fortunate I didn't loose an eye. She's always so right. :rolleyes:
Rob, you can loose things left and right now! You have the tool to find things.
/ Lost my draw bar #9
I found a groundhog once with my rotary cutter, but that's another story :)
My Dad lost my drawbar once, he looked all over the field for it. found it months later in the barn on the pile of wood where he had set it :)
/ Lost my draw bar #10
I hate losing stuff! For tools, pins and the things most likely to get dropped and forgotten, I spray flourescent orange paint on them. It's easy to leave a tool on the ground to blend in the woods and be forgotten, but with a splash of florescent orange on it...the handle will stand out and say, "here I am, come get me"! Same with chain...a little florescent orange on the ends. If you find your drawbar...
With clevises, make sure you put the main pin in from the top. Then if the locking cross pin becomes lost at least the main pin will not drop out.
/ Lost my draw bar #11
I have a friend that purchased one of those DeWalt camoflauged flashlights because he thought it was neat. I told him I can't find one bright yellow in the daylight, much less a camo. Add in a power outage and I am really in trouble! He lost his about two weeks later, and as far as I know, has never found it.
David from jax
/ Lost my draw bar #12
I bought some of the heavy duty lynch pins at TSC - they have a much stronger spring. They still get stripped off by the brush.
The kids lost an FRS radio out in the field last fall. We walked all over the place pressing the call alert. About 4 months later my wife found it while we were making fence. Still works!
Brad
/ Lost my draw bar #13
I paint high loss items Baby Blue. Contrasts with everything except the sky.
larry
/ Lost my draw bar
Found it! I started burning the brush and looked down and there it was. Now to find a better pin to hold it in.
/ Lost my draw bar #15
I have found that most of the tools and equipment can be found by the dog. Seem to leave a blood trail no matter where i go.
/ Lost my draw bar #16
It is getting hard to find a lot of hunting equipment that isn't camo these days.
I try my best not to buy any of it in camo, but sometimes I have to. Set it down for a minute & it is gone...
2006 Volvo VNM T/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM T/A...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A64557)
2008 21 Ft...
