Lost all the coolant today
   / Lost all the coolant today #51
The Bobcat mechanic did say the cylinder was defective. I believe where the hydraulic line attached. So maybe it wasn't me..
I am fairly certain you did not break a cylinder by going into relief. If cylinders broke that easy, I would break 10 a day by trying to lift something the tractor would not lift:) I wish I could spend a day with you and show you some things. I know we would have fun, and I am sure it would help you out a bit. Ask lots of questions when you don't fully understand something and we will try our best to help.
Thanks!! I'd like to meet up with you guys some day to discuss a million things. From FEL tips to brush cutter set up, and I haven't even touched maintenance yet! Following the OPs manual though.
Glad I didn't break that cylinder. It was one of those days, when I cracked the radiator, just figured I'd messed that up somehow also.
Enjoying the morning out in the field this morning, but looking for a gobbler to come by.
   / Lost all the coolant today #53
were you planning on sending a load of No. 5's his way?:)
   / Lost all the coolant today #55
Good tips on leveling. I just did about 1/2 acre that way, however there is one last trick. I take my drag field harrow and turn it upside down and drag across the area to do the final leveling. You can also use a section of chain link fence that has something to weight it down. I made one using 2 old fence posts and used fencing staples to hold the chain link in place. You run it fencing down with posts on top. Works great, especially for covering broadcast seed.
If your seeding the last step is to wheel role. I also do that before running the harrow above over i the area.
2015 MACK GU713 (A50854)
2015 MACK GU713...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
Kubota RTV500 (A47384)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
