lost 4Wd New Holland 45TC
   / lost 4Wd New Holland 45TC #1
1953viking
tc45 new holland
Can anyone help me figure this out.? I can't get the 4wd to engage. The lever works fine, the shaft locks up but the wheels still freewheel. I looked at all the associated threads. For 8 years everything worked fine, the engaging lever was very hard to move but it worked, now, its very easy.
   / lost 4Wd New Holland 45TC #2
The fact the lever effort has changed sounds suspicious. I assume when you say the "shaft locks up" you are saying when you move the lever, you can see the shaft that enters the trans case move properly?
The drive shaft has couplers on each end. Don't know if the NH's have issues with them but I can remember several TBN members losing FWD due to drive shaft couplers or pins failing on different makes.
If you can see the lever linkage is all working properly, I would check the drive shaft. I would probably also lift the front wheels off the ground, rotate them and confirm the drive shaft is rotating with them. Do all this an you have pretty well isolated the issue to inside the trans case. Not familiar with your tractor but usually you can take the top trans cover off and visually see most areas of the transmission like the FWD engagement shaft, fork and gears. This would help greatly in diagnosing the issue after everything else is ruled out.
2015 Ford Transit 250 Cargo Van (A51692)
2015 Ford Transit...
ALLISON TRANSMISSION (A53843)
ALLISON...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
Unused 2025 Spirit Electric Mini Golf Cart (A51694)
Unused 2025 Spirit...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2004 Ford F-550 Wrecker Truck (A51692)
2004 Ford F-550...
