Loss of RPM when hot
   / Loss of RPM when hot #1
Bobtrammell
Hey all you shadetrees, I have a little Ford 1220 HST that will not hold its rpms more than a few minutes. Once it gets hot, there is a significant loss of power.
What does this mean? My grandpa-like retired Ford mechanic says its the fuel filter, so I make sure I have clean air and fuel filters at all times. It doesn't matter what I do.
Who knows the steps of diagnosis to find out the problem??
Thanks, Bob Trammmell Little Rock
rdt@alltel.net
   / Loss of RPM when hot #2
Im new to desiel engines, but if it were gas you got a bad head gasket or intake, crank seals...sounds major to me. sorry to be the bearer of maybe some bad news.
Larry
   / Loss of RPM when hot #3
If this is something that just started happening recently, smell your fuel. I would not be suprized that it smells like gasoline. If this is the case, drain your fuel tank, change the fuel filter, and bleed the fuel system, even at the injectors. You won't be able to get every little drop but you'll get most of it. Once you get it running it should not take long for it to clear up. As far as any engine damage, unless you ran it for a long time (hours) everything should be OK.
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
EquipmentDealz (Preview Dates and Times) (A59213)
EquipmentDealz...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
New/Unused Electric Golf Cart (A57453)
New/Unused...
1996 International Water Truck with a Caterpillar Engine (A56435)
1996 International...
