Oil & Fuel loss of power
   / loss of power #1
massey sap tractor
newfane, vt.
1950's mf 35
I have a 1950's mf 35 and it runs great then after about 15 minutes it looses power. I need this tractor for my sugaring business so i need to figure it out ASAP.
   / loss of power #2
I flunked Mind Reading 101! Can you provide more info other then "...after 15 minutes it looses power..."!!!
Gas or diesel?
If it's a diesel, what ambient tempertures are you operating at? Do you have fuel at the injector pump or the outlet from the fuel filter when it quits? If you don't that's problem.Could be frozen water from contaminated fuel on the fuel filter or if you have summer diesel and cold ambient temps, gelled fuel. Could also be trash in the tank outlet screen.
If it's a gas, what is your electrical system operating at, 6v or 12V? Do you have a good spark when it quits on you? If you don't and if you have a 12v conversion, make sure that you have a real 12v coil with ~3.2 ohms primary resisitance OR a 6 v coil at 1.6 ohms primary resistance and a ballast resistor with about another 1.6 ohms of resistance.
Also check for high resistance at the key switch. If that checks out, make sure that you have an adequate fuel supply to the carb. Make sure the fuel cap is vented and make sure you have fuel at the sediment bowl. Make sure the "secret filter" in the carb inlet elbow isn't clogged.
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
Yale Veracitor 135VX Yale 12,150lb Forklift (A50322)
Yale Veracitor...
2023 Cat 310 Excavator (RIDE AND DRIVE) (A50774)
2023 Cat 310...
John Deere 7520 (A50120)
John Deere 7520...
