Loss of Power on JD 425
   / Loss of Power on JD 425 #1
Praireboy
Hello Folks
I just picked up a used JD 425. It looks well taken care of with 885 hours. It tested fine where I bought it from. But when I got home and did a quick test cut once I engaged the deck and started moving there was a lack of power, and once I go uphill while mowing, or turn it idles so low and sluggish it feels like it will stall. Without the deck engaged it seems just fine. If anybody has any ideas you would sure help a guy out. Thanks
   / Loss of Power on JD 425 #2
I would remove the deck, and hand turn the input shaft, see if it turns free. Does the deck sound noisy when engaged?
   / Loss of Power on JD 425 #3
You might also diagnose to make sure you are running on both cylinders. They run smoother than you would think on just one. At an idle, pull one plug wire with a thickly gloved, dry hand. If the other cylinder is dead, it will die. Replace and do the other side.
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
