Loss Of Power and Lots Of White/Grey Smoke On Mitsubishi 3 Cylinder Diesel
   / Loss Of Power and Lots Of White/Grey Smoke On Mitsubishi 3 Cylinder Diesel #21
You could check the compression on each cylinder as it could be a blown head gasket?
   / Loss Of Power and Lots Of White/Grey Smoke On Mitsubishi 3 Cylinder Diesel #22
Going to check compression and check for excessive pressure in the radiator before doing compression test. I have heard parts are not available so I will be trying block sealer if it is not a head gasket.
   / Loss Of Power and Lots Of White/Grey Smoke On Mitsubishi 3 Cylinder Diesel #23
Be wise; make an early purchase of a replacement as the present one will only cost money and probably not preform properly without a Complete rebuild.
Some cracks are hard to find without proper diagnostic equipment and procedures.
   / Loss Of Power and Lots Of White/Grey Smoke On Mitsubishi 3 Cylinder Diesel #24
I am looking for a replacement engine or mower. The 200 series Toros weren't the heaviest duty but we've got 20 years out of it for $2400. It is in pretty good condition other than the seat and the engine at the moment. I was told the Mitsubishi L3E Toro blocks were proprietary and other L3E blocks might not be a drop in.
There is a Toro L3E about 4 or 5 hours away for $1.000. I'd have to do a compression test before buying.
With a new head or block not available, I don't see many options if I have cracks instead of a head gasket issue.
I'm wide open to suggestions
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
(7) UNUSED IRANCH PORTABLE DUMP HOPPERS (A54757)
(7) UNUSED IRANCH...
2014 Infiniti QX60 AWD SUV (A53424)
2014 Infiniti QX60...
