Oil & Fuel Loss of Hydraulic fluid
   / Loss of Hydraulic fluid #1
tstex
Platinum Member
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to All,
This is my first post in the forum. I have 1997 Kubota M5400S and a credible person wanted to borrow my tractor to put-out a round-bale of hay. They borrowed it around 8:00pm CST this last friday night [dark]. When they returned the tractor around 9:00pm, a hydraulic hose was busted on the frt-end-loader and h-fliud was coming out pretty well. Everything was fine when I used it earlier in the day.
Since it was dark, I am not sure how much fluid leaked out, especially when the 1500lb bale was on the back. I checked the h-fluid dip stick and it did not even register anything: it usually reads 1/2 - 3/4 full.
After I get the h-hose fixed/replaced, was wondering what steps I should take to refill and not over-fill and make sure the transmission or anything else did not take a hit?
FInally, I bought Universal 303 H-Fluid from the Kubota dealer which is in there now, they no longer sell it, only OEM kubota h-Fluid [$80/5 gal]. Is it ok to mix with another compatible when I refill? Any good compatible h-fluid recommendations?
Thank you very much for your help in advance,
tstex
   / Loss of Hydraulic fluid #2
I always put in a gallon at a time and watch the dipstick until it shows full. I then go out with the tractor and run it up and down some inclines to make sure all cavities have fluid in them and then re-check the dipstick and fill according to readings. Ken Sweet
Onsite begins 8:30am / Online begins 9:30am (A50121)
Onsite begins...
2013 TOYOTA TUNDRA(INOPERABLE) (A52472)
2013 TOYOTA...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
