Loss of Hyd Pressure "Too Fast" ??
   / Loss of Hyd Pressure "Too Fast" ?? #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Loss of Hyd Pressure \"Too Fast\" ??
I've got a 4210 with 420 FEL & 47 BH and when I'm done playing, whoops, I mean working & put it back in the garage; within about 2 hours, the loader & hoe are on the floor. I don't think that hyd pressure should be bleeding off that fast. Is this common ???? As a side note, everything seems to be working fine, when I unhook & store loader, it doesn't move & when I've got my 84"RB hanging off the 3PT Hitch, it stays for days where I left it. Your Thoughts .............
Eric
   / Loss of Hyd Pressure "Too Fast" ?? #2
Re: Loss of Hyd Pressure \"Too Fast\" ??
Eric,
</font><font color="blue" class="small">( I mean working & put it back in the garage; within about 2 hours, the loader & hoe are on the floor. I don't think that hyd pressure should be bleeding off that fast. )</font>
The issue has been addressed by Deere. Here is a link to their leak down testing procedures. Loader and backhoe boom/bucket lower slowly while parked
</font><font color="blue" class="small">( when I've got my 84"RB hanging off the 3PT Hitch, it stays for days where I left it. Your Thoughts .............
)</font>
It is a good practice to lower all hydraulic implements when you park the tractor. That way you know that they won't drop on someone or something unexpectedly. In addition, three point implements which have leaked down won't raise suddenly on startup.
Thanks for Link, I'll check measurements.
Eric
   / Loss of Hyd Pressure "Too Fast" ?? #4
I don't have much knowledge on hydraulics.
I've always been wondering why the 3pth with 600lbs would stay in the same position for days but not the loader/bucket ?
Can't a circuitry similar to the 3pth be used for the SVC ?
   / Loss of Hyd Pressure "Too Fast" ?? #5
Your 3-point only has one cylinder that could leak down and it only has one spool that controls it. The loader on the other hand has 4 cylinders that can leak down and you have 2 spools in the control valve that can also leak. So the loader (and a backhoe) have a greater ability to leakdown.
   / Loss of Hyd Pressure "Too Fast" ?? #6
My 790 and 419 loader has a bad leakdown problem. The dealer has replaced all cylinders as well as the SCV in an attempt to fix it. It still leaks bad (while it's running too.) JD has some issues with their hydraulics.
202483 (A54757)
202483 (A54757)
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2019 International Bucket Truck (A55973)
2019 International...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
John Deere 5075E (A53317)
John Deere 5075E...
