loosing RPMs
   / loosing RPMs #1
mike123
Bronze Member
Saskatchewan,Canada
Toolcat B 2004
It was 30 below celcius the other day and I was loosing RPS when ever I put a load on the engine. I am sure I have some water in the fuel which is causung it to freeze up.
How much desiel conditioner should I put in the tank?
I read there is a drain on the fuel filter, do you know where and how I get at the fuel filter?
Thanks Mike
   / loosing RPMs #2
I have a Toolcat D-Series and the info (with pics) you are looking for is on page PM-20 of the 5600 Operation & Manintenance Manual.
Basically it says, "The fuel filter is located under the right side access cover. Loosen the drain at the bottom of the filter element to remove water from the filter. Close the drain."
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2013 Ford E350 Box Truck (A47384)
2013 Ford E350 Box...
