Loosey Goosey FEL Joystick
   / Loosey Goosey FEL Joystick #1
jbrumberg
Elite Member
Cummington, MA
New Holland TC29DA, John Deere D130
I have a NH TC29DA. My FEL joystick started to get pretty loose so I removed the rubber joystick boot and tightened up the top nut which has a lock washer. I noticed that the joy stick is threaded and threads through the diverter countrol housing with a the threaded end protruding from the bottom. My question- did I lose a bottom locking nut and if I did what size nut/nylock nut do I need? Thank you in advance for your responses. Jay
   / Loosey Goosey FEL Joystick #2
Mine comes loose every once in a while and I don't even take it apart. I just spin the joystick in a clockwise position and it tightens up again. I am not sure if there is a lock nut underneath. But I do know when I spin it the one turn clockwise it gets real tight again. If you wish I can take mine apart and look for you? Someone here may have the parts manual on CD that can take a picture of it for you also?
murph
   / Loosey Goosey FEL Joystick #3
I've had plenty of experience with joysticks, Jay.:eek: As I remember, there is no nut on the bottom of the threaded rod, just the jamnut on the top. If it keeps coming loose, you might add a drop of Loctite to the threads, or you could remove the shaft and add two jamnuts to the top threads. I think I'd opt for the Loctite.:)
   / Loosey Goosey FEL Joystick #4
My joystick did the exact same thing on my TC29. I took my rubber boot off and just tightened the nut like you did. Mine did not have any type of lock nut or washer on the underside so I don't think there is supposed to be one.
Thanks To All :D :
Thcri you do not have to take yours apart for me, Jinman thank you for the Loctite suggestion, and Zipperhead0 thank you for your response. Jay
   / Loosey Goosey FEL Joystick #6
I guess RAT hasn't seen this thread yet.....eh Jim !!
   / Loosey Goosey FEL Joystick #7
"Loosey Goosey" I use those words from time to time... made me giggle... I too have your issue, seems the vibs make the stick come loose (that sounded weird) anyway, I keep a wrench in the tool box, but I like the idea of loctite, didn't even think about that one... :p
M.
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
434669 (A48836)
434669 (A48836)
