Loose wheel bolts
/ Loose wheel bolts #1
Anonymous Poster
Epic Contributor
Any of you Kubota owners ever have wheel bolts coming loose on your tractors,like I have on my John Deere 4400?
/ Loose wheel bolts #2
I've seen very occasional posts where they needed to be re-torqued on a new unit after a bit of use or service, but I think that is standard operating procedure on all tractors. I don't recall seeing anything about the Kubotas having a problem with the lug bolts loosening though. Closest thing that I recall is some older style hubs coming loose from the axle on some older models that had the option of changing the tire width...if i remember right, that was a pretty easy fix, though, and pretty rare at that....
/ Loose wheel bolts #4
Part of my regular inspection is checking all fasteners on my L3010. Once I had a wheel nut back off about 1/3 of a turn. This is the sort of thing that has less to do with the type of tractor than in implementing a good, common sense preventive maint program.
Pete
/ Loose wheel bolts #5
After I read all of the posts in the JD forum last week about this problem I checked mine this weekend (Kubota M4900). All of them were tight but I've only got about 20 hours on it.....Doggone it.
TBone
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
John Deere 400 Rotary Hoe (A66408)
John Deere 400...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
