Tiller Loose tines on Tiller
   / Loose tines on Tiller #1
PaulInMi
South-Eastern Michigan
Kubota 3010HST
This weekend after doing several tilling jobs(60" King Kutter w/less than 20 hours) I noticed that most of the bolts that attach my tines were loose and one had actually come out and disappeared.
Does this happen to all tillers and if so what can be done to prevent it? Perhaps a lock nut over top the original nut?
Thanks in advance.
Paul
   / Loose tines on Tiller #2
I would think lock washers under the nuts would do it, but a second jam nut if the bolts are long enough. I've never even checked the tightness of the bolts on my Bush Hog, but after 6 years I've never had one get loose.
Bird
   / Loose tines on Tiller #3
I would replave the nuts with nyloc nuts. This would keep them from working loose.
   / Loose tines on Tiller #4
What does the owners manual say about maintenance?
I would think that they wouldl have a suggested maintenance schedule. Also, there's a possibility that the bolts and nuts weren't tightened in the first place.
The manual doesn't say anything reference the tine bolts. Luckily we had a 7/8" wrench w/us so we tightened them in between our 2nd and 3rd job. After the 3rd job they were just as loose again.
They do have lock washer but they don't seem to be helping.
Thanks again.
Paul
   / Loose tines on Tiller #6
I'm on my second tiller and as of yet never had that problem. I belive they were never tight to begain with.
   / Loose tines on Tiller #7
Sounds like you need to talk to the dealer and have them service it.
Maybe it's possible that the wrong type of bolts and nuts were used.
   / Loose tines on Tiller #8
Paul,
I'd try some Blue (242/243) Loctite on them and see if that helps. If they still work loose, I've used the Green Loctite in some applications before and while it can be removed with hand tools, it will take considerably more force. If all else fails, you can use one of the Red Loctites, but removal will then require the application of heat with a torch to soften the material.
Hoss
2024 JOHN DEERE 50 P-TIER EXCAVATOR (A52709)
2024 JOHN DEERE 50...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
1994 International 3800 Bus (A54814)
1994 International...
Cushman Electric Cart (A55853)
Cushman Electric...
2012 Big Tex 25ft. 9 Ton T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 Big Tex 25ft...
2024 Timpte 40ft Hopper (A56435)
2024 Timpte 40ft...
