loose stearing
   / loose stearing #1
beagle man
missouri
jimma
When I turn the stearing wheel, it moves several inches before the tires start turning, verry slow to react to turning, Just had the Hydralic Cylinder rebuilt, did not fix the problem,,, it was leaking so needed to be rebuilt anyway, any thoughts on this... I see no fluids on the concrete when I turn the wheel left or right, and it does stop when I get to the end of the turn... just slow to respond to the turning of the tires.
   / loose stearing #2
I would guess that the fluid is bypassing in the steering box. Also check the pressure output of the pump.
   / loose stearing #3
Check the hydraulic box at the end of your steering column to make sure the mounting is not loose.
   / loose stearing #4
Bypass is rarely reported in the steering controller, although loose mounting bolts are not out of the question. That said, but you might want to check your work on the cylinder rebuild. To me it sounds like the steering cylinder itself is still bypassing.
//greg//
   / loose stearing #5
Everyone seems to think the problem is related to hydraulics, but I suspect that's not where the problem lies.
Yours will look a little different, but most steering boxes have a lash adjustment screw and locknut, which is used to adjust the lash (slack or pressure) between the steering gears. Have you tried checking the lash adjustment?
   / loose stearing #6
Beagle Man, exactly what type tractor are we talking about here? Does it have a steering gearbox, or is it all hydraulic, with a cylinder down in front and a rotary vane pump at the base of the steering colunm?
   / loose stearing #7
And just to add to the possible confusion, the tie rod ends on Jinma tractors are adjustable for lash-up in the ball joint parts. They do get loose and make for sloppy steering.
   / loose stearing
I will look for this adjustment, the book does not have the above information, thank you for your response.
   / loose stearing
rich, new tie rod ends, toe adj, RonMar, it is a farm pro 200 series
   / loose stearing #10
When I turn the stearing wheel, it moves several inches before the tires start turning, verry slow to react to turning...and it does stop when I get to the end of the turn... just slow to respond to the turning of the tires.
To me, that still sounds like steering cylinder bypass. It's not impossible to improperly or incorrectly overhaul a cylinder. And - to the best of my knowledge - Beagles' steering last adjustment doesn't exist on a Jinma steering controller.
//greg//
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
2020 COLOMBO TM LOT IDENTIFIER 192 (A53084)
2020 COLOMBO TM...
DEWALT 3600 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3600 PSI...
1999 MORBARK 3800 WOOD HOG GRINDER (A53426)
1999 MORBARK 3800...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
