Loose Joystick -FIXED !
   / Loose Joystick -FIXED ! #1
KiotiKevin
Port Morien, N.S., Canada
Kioti NX4510
Once again - problem solved thanks to all who posted and Tractorbynet.com. I removed the seat and the 2 bolts that hold in the Joystick box and your right, it was a bugger getting that boot lifted. For those of you who have to do this, there is a lip on the rubber that is tucked under the bottom edge of the box. I used a 22mm wrench to tighten the brass nut and it was only a very slight tug on the wrench, as a posters have said, be careful the assembly is only made of plastic.
Thanks again - Happy tractoring !
Kevin
   / Loose Joystick -FIXED ! #2
Happy to hear you fixed it without any issues.
2018 FORD F-150 (A52472)
2018 FORD F-150...
John Deere 7000 8 R Planter (A50515)
John Deere 7000 8...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
SCAN TO RECEIVE TEXT UPDATES (A51244)
SCAN TO RECEIVE...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
