Loose bolts on loader.
   / Loose bolts on loader. #1
Pop-rick
Mahindra 3510
I just wanted to let you know I found loose bolts on my front loader. The problem I found was when it was manufactured the frame rail that bolts to the engine was threaded. The bolts are tight but it doesn’t seem to pull it together. I drilled the thread out of the steel rail so it could actually tighten.
   / Loose bolts on loader. #2
What year is your machine? The early 3510/4110s had issues with loose and broken bolts on the loader frame. From the factory the rails are not threaded, that must have been someone trying to fix it.
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
2025 GM670 Compact Track Loader Skid Steer (A53421)
2025 GM670 Compact...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
UNUSED TELESCOPIC LADDER - 3.2M (A54757)
UNUSED TELESCOPIC...
