Rotary Cutter loose blades
   / loose blades #1
threebsfarm
bergen n.y.
john deere
changed blades on my lx5 bush hog,tightened nuts down tight but blades are loose and scrape sides of deck. what did i do wrong?
   / loose blades #2
Welcome to TBN.
I can't answer your question, but someone should be along soon that can.
   / loose blades #3
Are you sure they are the correct blades?
   / loose blades #4
:welcome: check dem blades
   / loose blades #5
I'd go with the other's comments.
The blades being loose would indicate that the new blade's bolt hole is too large and, maybe, the blade is too thin.
The large nuts on a rotary mower can only be tightened so far before they run into a ridge on the bolt. This designed slight looseness allows the blade to rotate out of the way if something is hit. The fit has to be exact.
The blades hitting the sides is another giveaway that the blades are wrong. They should miss the sheet metal by 1" to 2".
My advice: Take the old blades, the new blades, the large nuts and bolts to a tractor dealer and match them all up correctly. Tractor Supply might have what you need.
What brand of "bush hog" are you working on?
Road Brute Flat Deck Trailer (A50514)
Road Brute Flat...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
(2) Oliver Wheel Weights (A50515)
(2) Oliver Wheel...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
2018 Honda CR-V LX SUV (A50324)
2018 Honda CR-V LX...
