SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,338
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I recognize the tendency for that problem when the grass is good and dry and slips thru the chute easy. From your pictures I thot I saw a compounding matter on yours but waited to take a look at my baler to compare. My bale chute is a good 5' long - yours looks a bit shorter. It doesnt take much loss in length to put you over the edge for being able to control tightness with the bale squeezer with slippery hay. Maybe a little more twine tension would bring back better control when you do the slippery stuff. Then loosen it back up after cuz tight twine accelerates wear a bit.Hi I baled some grass mix hay yesterday and i was getting loose bales tightened tension and was still not able to get twine tight on the bales.
The grass was soft and when I used the baler (565) last year to bale alphalpha/timothy the bales where perfect.
I was wondering if I could not get tight bales it was because of the texture of the hay ???????????????????//
larry
