Looking to buy the right tractor the first time!
   / Looking to buy the right tractor the first time! #21
You may be a new poster but you certainly are a smart dude. You already know the key ingredients to CUT's. That being the right size, right tranny, right dealer and a good product. Both Kioti and Deere are good units and if your Deere dealer treats you right then you are headed in the right direction. Going up to a 6420 is a huge jump from a 4000 series. I have yet to see the 20 series but the 4700 I ran (only 5 hours hours so I'm not an authority)was surprisingly strong. It developed its torque very low and the loader was impressive. Believe it or not I was digging a basement for a guy and it worked well. As for haying it depends on your equip and field conditions. I use a 7210 or 6400 for our baler, a 535 that makes 6 foot bales, but that same setup would not work my relatives who have hills and require 30hp more. You could square bale with it on flat land but overusing a tractor is not a smart move.
This is just a thought and maybe a bad one but for 30G you could buy a small CUT and a decent used utility tractor. Utility tractors as a whole require much less work that their smaller counterparts.
   / Looking to buy the right tractor the first time! #22
The 6420 has a cluthless transmission called the Infinitely Vairable Transmission (IVT). Click here for more info about the IVT transmission. This will be your best bet other than HST.
Hope this helps. Good luck! /forums/images/graemlins/smile.gif
   / Looking to buy the right tractor the first time! #23
</font><font color="blue" class="small">( RedDog,
If I recall correctly, I was quoted about $35K for the Kioti DK65C with cab and fel.
Thanks,
JAGJAG )</font>
Wow!! I can't believe that price. I do not have a cab, just the sunshade. I do have the quick attach plate and 7' bucket. My tractor was more than 10K cheaper than that!!
I might have to advertise mine if they are reaching these prices. /forums/images/graemlins/grin.gif
RedDog
   / Looking to buy the right tractor the first time! #24
</font><font color="blue" class="small">( Wow!! I can't believe that price. )</font>
That quote was pretty out of line from what I've seen. John
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
48 Inch Farm Jack (A57454)
48 Inch Farm Jack...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
New/Unused CFG Industrial QH12R Mini Excavator (A57453)
New/Unused CFG...
