looking to buy my first disk mower... deere kuhn?
   / looking to buy my first disk mower... deere kuhn? #1
quadmaster50
Bronze Member
Bloomington Indiana
Bobcat T770, T650, 435, Case 450C
Looking for advise on buying my first disk mower, been using bush hog with sides cut out for a long time...
found a deere 260 that leaks oil out cutter seals for 1800.00 and a kuhn 8.5' that is ready to go for 2000.00
Are these decent mowers? I'm sure they are 1980's or early 90s' so they are OLD!
Ill be using a 55HP kioti DK55 4x4
   / looking to buy my first disk mower... deere kuhn? #2
Very little difference in older model JD & Kuhn's except the color of the paint as Kuhn built cutter for JD . Parts will interchange. I'd buy the cutter that is field ready if amount of wear(use) is similar.
   / looking to buy my first disk mower... deere kuhn? #3
Have you considered a drum mower. You can get a wider cut with the same HP tractor, and they are generally cheaper. The new Kuhn and also Kubota disk mowers appear to be built a little heavier than other models. One question is what brand of dealers you have near you to get support and parts - also check out parts prices. Hope this helps
   / looking to buy my first disk mower... deere kuhn? #4
Personally I prefer my dick unmowed, but thats just me.
I haven't really heard about a drum mower to be honest, Ill look into them for sure..
And as for dealers jim i have a few deere dealers within 20 miles or so.
Cant find any disk mowers around at all, I al worried my 5500 lb tractor will not handle a 8' disk mower.
   / looking to buy my first disk mower... deere kuhn? #7
If you're worried about your tractor not handling the cutter weight you could put cutter on a caddy. Caddy is much easier to attach to tractor than just the cutter and IMHO caddy follows contour of ground better
   / looking to buy my first disk mower... deere kuhn? #8
KRONE!111111111111111
   / looking to buy my first disk mower... deere kuhn? #9
Krone makes a good product IF you have dealer support, their dealer presence in some states is not that great but I do see that there is at least 4 of them in IN vs the nearly 60 in TX. Based on the size of the states TX has approx twice as many dealers per/sq mile.
   / looking to buy my first disk mower... deere kuhn? #10
+1 on the Drum Mower. Try SFI in Texas. Lately I've been buying my blades from Webbs Sickle Service. They have some German made blades that last longer.
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
2018 Nissan Titan (A50323)
2018 Nissan Titan...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
