looking to buy my first disk mower... deere kuhn?
   / looking to buy my first disk mower... deere kuhn? #1
quadmaster50
Bloomington Indiana
Bobcat T770, T650, 435, Case 450C
Looking for advise on buying my first disk mower, been using bush hog with sides cut out for a long time...
found a deere 260 that leaks oil out cutter seals for 1800.00 and a kuhn 8.5' that is ready to go for 2000.00
Are these decent mowers? I'm sure they are 1980's or early 90s' so they are OLD!
Ill be using a 55HP kioti DK55 4x4
   / looking to buy my first disk mower... deere kuhn? #2
Very little difference in older model JD & Kuhn's except the color of the paint as Kuhn built cutter for JD . Parts will interchange. I'd buy the cutter that is field ready if amount of wear(use) is similar.
   / looking to buy my first disk mower... deere kuhn? #3
Have you considered a drum mower. You can get a wider cut with the same HP tractor, and they are generally cheaper. The new Kuhn and also Kubota disk mowers appear to be built a little heavier than other models. One question is what brand of dealers you have near you to get support and parts - also check out parts prices. Hope this helps
   / looking to buy my first disk mower... deere kuhn? #4
Personally I prefer my dick unmowed, but thats just me.
I haven't really heard about a drum mower to be honest, Ill look into them for sure..
And as for dealers jim i have a few deere dealers within 20 miles or so.
Cant find any disk mowers around at all, I al worried my 5500 lb tractor will not handle a 8' disk mower.
   / looking to buy my first disk mower... deere kuhn? #7
If you're worried about your tractor not handling the cutter weight you could put cutter on a caddy. Caddy is much easier to attach to tractor than just the cutter and IMHO caddy follows contour of ground better
   / looking to buy my first disk mower... deere kuhn? #8
KRONE!111111111111111
   / looking to buy my first disk mower... deere kuhn? #9
Krone makes a good product IF you have dealer support, their dealer presence in some states is not that great but I do see that there is at least 4 of them in IN vs the nearly 60 in TX. Based on the size of the states TX has approx twice as many dealers per/sq mile.
   / looking to buy my first disk mower... deere kuhn? #10
+1 on the Drum Mower. Try SFI in Texas. Lately I've been buying my blades from Webbs Sickle Service. They have some German made blades that last longer.
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
