I have been looking at buying my first tractor and wondering if there is something that I should at before final decision.
I have looked at used and new in a few other brands and came down to used 2018 1025r with 440 hours for $18,000 cad, the used GC1720 for $17,500 and the new BX23s for $6500.00 more.
The salesman said the Massey is a better more redefined unit and a little more powerful but both are great units and will do the same job. The dealer probably sells 15 Kubota's to 1 Massey in the compact market.
I will probably put about 200 hours on it over the next year or so and then the usage will drop to 50 per year. Its main purpose will be to redo the property landscape, maintain 100 FT gravel driveway and dig footings for new deck and install concrete pad for garage. The property is 130 FT x 275 FT
The tractor that I am looking at is a 2016 GC1720 TLB with 130 hours. It was a little dirty for a close first look but the only things that I noticed was HYD fluid on backhoe cylinder closet to the seat was a little wet. Possible leak at seal. I did not see any pitting or marks. The only other thing was one on the teeth on the backhoe has loose.
The diff lockup floor leaver seemed stiff and I did not know how to test and see if it worked.
I don't know when the HDY filter should be changed but the one on the tractor looked original because it was the same color as the diff. I assume that if was painted when built.
Is there any common problems that I should look for on the tractor and is this tractor a solid trouble free unit? The dealer sells both Masseys and Kubota's.
The low hours seems worth taking the risk on a used unit. Still has 18 months powertrain warranty remaining.
