Looking to buy a 240D
   / Looking to buy a 240D #11
Exhaust getting past the piston rings and into the crankcase. The gas "blowsby" the pistons and rings. Makes the engine more inefficient and creates positive pressure in the crankcase.
   / Looking to buy a 240D #12
ok so what causes blowby
Anything that will cause pressure in the crankcase, (should have a vacuum), generally bad rings, but could be oil overfull, bad dipstick seal or bad crankcase vent.
   / Looking to buy a 240D #13
Worn Rings on the pistons and worn sleeves/cylinder walls.
I have been busy with ministry and have not had time for hobbies lately. I was just today complaining that I have not done a single thing in the shop like welding or fabricating something for a long time. I feel like I am just getting caught up now and was thinking that tomorrow -- But they are predicting 4-8 inches of white powdery stuff tonight so maybe my shop time will be delayed again. :(
Mike
   / Looking to buy a 240D #14
I don't think there is a vacuum in the crankcase on these old diesels. Rather, a slight positive pressure from minimal blowby.
What makes the crankcase vacuum on a gas engine is the PCV tube between the crankcase and the intake manifold, beyond the throttle butterfly, where a vacuum exists at all times except full throttle. (The purpose for that line is to suck crankcase vapors into the intake so they get burned in the engine). A diesel has no butterfly, it is full throttle all the time with engine power controlled only by limiting the fuel quantity.
   / Looking to buy a 240D #15
Worn rings on the piston causing combustion gasses to "blowby" the piston skirts into the crankcase.
Im sure im not the first to respond to this as i see there is another page, and i have not clicked to the second page to read them yet, so sorry if its a repeat.
   / Looking to buy a 240D #16
Yep, depending on the article, it appears that a google on "diesel crankcase vacuum" gets about a 50/50 result of slight vacuum or slight pressure.
   / Looking to buy a 240D #18
... but if there is no PCV hose (or modern smog control components) then any crankcase vacuum can only be created by the 'road draft tube' moving quickly down the highway per Wikipedia. There isn't any other way to make a vacuum in an otherwise-sealed crankcase.
And I doubt these go fast enough to make enough vacuum that way to exceed blowby.
This has been great. I was all packed up with my trailer, towing straps, tools, my inspection checklist but unfortunately, today I had some guests who stayed longer than planned and I could not get to see the tractor because it would be dark by the time I got there - a 2.5 hour ride. Also the owner called and told me that when he started the tractor and engaged the BH, he broke a CV joint like coupler that he had welded on that powered the BH via the PTO. He has another interested party coming on Sunday morning and I cannot get up there for another two weeks, so it looks like I may have missed out on this one.:(:(:(
BUMMED OUT
So my search continues - I also confirmed the hours to be 2400 - not as bad as the 4000 I thought I originally heard. Thanks and Happy New Year
Scott
   / Looking to buy a 240D #20
BUMMED OUT
Scott
Thats not that bad i would have driven and taken sever lights to look.
2018 Infiniti Q50S Sedan (A50324)
2018 Infiniti Q50S...
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
2025 Platform Safety Basket Attachment (A50322)
2025 Platform...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
Kubota SVL75-2 (A50120)
Kubota SVL75-2...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
