Looking to buy a 240D
   / Looking to buy a 240D #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
I am going to look at a 240D with high hours. I have been reading up on other posts for info and have a few questions.
Is there anything particular to look for in this model? Does this model have a water pump? does it have a hundred or thousand hour meter - and is it true the hour meter spins fully at full rpm's and slower at lower rpm's? . How do you check for blow by?
What would a high hour (4000) 240D with FEL and BH be worth?
   / Looking to buy a 240D #2
To answer your questions with my opinion. Trouble spots, umm, make sure the 3 pt works. Thats about it and make sure all gears in all ranges work and wont jump out. The hour meter is 3 places with a tenths place (really 4 #'s shown) So once the tractor reaches 999.9 hours it will flip back to 000.0. You are correct the tractor will turn 1 hour on the meter at 2400rpms for 1 hour of run time. So at 1200rpm it will take about 2 hours of wristwach time to get 1 hour to show up on the hour meter. I usually will bushog for say 4 hours and end up with 2-3 hours on the meter depending upon how fast the engine is going and how much i slow down etc.
A 4000 hour meter tractor to me would only be worth about 1-1.5K w/out loader, that would be without a rebuild, with a decent rebuild you can be creeping back into the 2-3k range. Thats my opinion though. Most say these that actually have 4000hours on them are ready for something to need to be done, weather its new rings and bearings or something more like pistons cyl hone rings and bearings etc. And to know it has 4K on it it would have to be the original owner or second that was told by the first as there is no way to tell.
As far as blowby, there should be a rubber hose about 1/4 coming off the side of the block on the right side as your sitting in the seat. It will run down and just end in mid air around the hard hydro lines. If there is a lot of oil slobber blown on the side of the block this would be a good sign of blowby. The rubber hose may also not exist, in that case there is a fitting still on that side that it just pushes onto, if i remember right its a metal j tube pointing down that the hose should be on. Its a little above the injector pump and foward a little. I would run it up to 2400rpm, the fully ratted HP rating and drive around while looking at that tube and see if you see smoke or mist coming out of it, you can also let it run at 2400rpm and stand beside it and feel for air mist coming out, mine has just a little pressure , which i think is just from the rotation of the crank inside, but no spray mist or anything, a drip now and then but not constant. You also should put the tractor under a load and observe this weather it is a boxblade you put down to "work" the tractor or a disk in the ground or a bushhog that you set really low to tax the motor, it will let you know and if you dont see blowby at that point chances are it dosent have it.
   / Looking to buy a 240D #3
Yes, it has a water pump. I believe the 240 has a crankcase vent tube that comes off right under the muffler. Won't be unusual to have a little blow coming out but shouldn't be excessive. Here is excessive. YouTube - Yanmar 155D Crankcase Vent My owners manual for my ym2002d says hour meter is calculated at about 2200rpm. I don't know which hour meter the 240 has. Has the tractor ever been overhauled? If so, the high hours would not be as important. I'll stay away from putting a price.
   / Looking to buy a 240D #4
Clemsonfor posted it to the (T) for our area. Here is a pic. of the vent tube on a Ym2000. It's the shorter Blk. hose coming out of the block above the Blk' fuel line. It's basicly the same as the US. Ym240. Throttle linkage works the opposite and I believe you only have 540 or first gear PTO. and the Grey has three. Everything else is pretty much the same. You will find all kinds of Info. on here for these models with alot of owners :cool:
Carey
Thank you all. this is very helpful. I am excited that this animal has a backhoe but my heart sank when I heard 4000 hours. I have to ask if it has been rebuilt etc, but he did not mention it so far. A huge concern of mine.
By the way.... what is the (T) for our area?
   / Looking to buy a 240D #6
Wow!!! I guess I'm showing my Age. (T) is Old School or For Precise Discription or to the Point. ;) Where are you Located ?
   / Looking to buy a 240D #7
Unless you are really into working on tractors, I would steer clear of a 4000 hour compact tractor. Most gray markets of the same age have less than 1000 hours.
   / Looking to buy a 240D #8
I would not be afraid of 4000, but am not sure how the seller knows that it has that many hours. Maintenance and condition are much more important than hours. If all fluids look and smell right and everything works without too much sloppiness I would say go for it. That is a very popular model with lots of parts and advice available. I have heard people say that that little Yanmar engine will go 6000 hours or better before an overhaul is needed.
Mike
   / Looking to buy a 240D #9
MJ where have you been, not seen you here much lately. Hope you and yours had a merry christmas.
   / Looking to buy a 240D #10
ok so what causes blowby
2014 CATERPILLAR 349FL EXCAVATOR (A51242)
2014 CATERPILLAR...
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
