Looking to add a 3rd function hydraulic to my nh
   / Looking to add a 3rd function hydraulic to my nh #1
sc22fo
nj
New Holland tz22da w/10la loader
Want to add a 3rd function to my nh tz22da w/10la loader looking for ideas that dont cost a ton of money. Thought maybe I could build my own, just not sure where to start. Any info would be good info. Thanks
   / Looking to add a 3rd function hydraulic to my nh #2
There are several third hand hydraulic kits on the web. I am looking at the one
at Everything Attachments.
   / Looking to add a 3rd function hydraulic to my nh #3
Do you want a kit that is already made up with min work, or do you want to obtain all the parts and do it your self?
What the dealer or manufacturer does, is get a solenoid valve set up, and all the hoses and fittings that may work with your tractor.
You can do the same thing by shopping around for all the parts.
The 3ed function valve can be added just about anywhere in the series hyd circuit depend on where you have space for it.
JJ
I thought if I got all the parts it might be cheaper but not sure. I checked out a few kits just not ready to drop $700 or so. Know of anywhere good I could shop for the parts?
Thanks
Thanks JJ.. Now I just have to put the pieces together. Wish I knew more about hydraulics :)
   / Looking to add a 3rd function hydraulic to my nh #7
Doing things your self is good way to learn about hydraulics, plus understanding your tractor manual and asking questions.
Sure a dealer can do a super job, but you probably would not learn anything about your tractor hydraulics.
One of the first add on to your hyd system you could do is to add a 3000 psi hyd gage where you can see it or build a hyd test set like these.
You can use the hyd gage to monitor , troubleshoot, and analyse your hyd system.
The link below is how the 3ed function valve is installed in the series hyd flow path.
http://www.wrlonginc.com/Hyd DO3B Flow Diagram.pdf
You right! I do like learning things about my tractor and hate paying for something that I can do myself. So if I understand correctly I would need the 12v solenoid valve, sub plate, hoses and a switch and I would have my 3rd func? Seems like its alot cheaper making myself.
2018 Gatormade 20+5 Gooseneck Trailer (A53473)
2018 Gatormade...
Set 4- 10-16.5 tires/wheel for bobcat (A53421)
Set 4- 10-16.5...
2014 FONTAINE TRAILER CO. STEPDECK (A53843)
2014 FONTAINE...
19200 (A50324)
19200 (A50324)
RING 2 STARTS HERE @ 9:15 AM (A54756)
RING 2 STARTS HERE...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
