Looking for Zero Turn-Swisher?
   / Looking for Zero Turn-Swisher? #1
pbutler
I have about 2.5 acres of yard we are seeding for just completed home. Some of it is a little rough so not a real easy mow. I am looking for a new or relatively new Zero turn-probably 54" or larger deck if possible.
I have larger tractors for farming operation so I don't need to do anything but cut grass so don't need a garden tractor.
I love the Dixon, JD, and Cub Cadet commercial mowers but $7-8k is just out of my budget. I was going back and forth between the $3,000 Cub Cadet residential at Farm & Fleet in trying to find a used commerical mower for maybe $4,000. The more I read here I am not sure the residential will last for me.
I stopped by rural king the other day and they had a Swisher zero turn. It isn't pretty but it looked much more heavily built than the residental mowers. It wasn't pretty but looked tough. I believe the deck was about 54" and it had a 22hp mower. It was listed for $3,900.
Anyone have any advice? Swisher Good or Bad? Other options?
   / Looking for Zero Turn-Swisher? #2
No specific info [it's been almost a year since I seen one and didn't even demo it], but my own "once over" thoughts:
IMHO, they're not planning sever conditions or long life if they're using Intek engines.
I thought it had an EZT or IZT [these are "integrated transmissions" not meant for extended or rugged used], but could be wrong. On that note, I know CubCadet has two models now using Hydro-Gear's ZT-2800 (beefed up IZT that {info gettng fuzzy here} has a oil resivoir and perhaps charge pump). Time will have to tell, but this might be a good compromise for the several acre yards.
You will pay for a little name recognition with JD, SCAG, etc; else, I'm pretty convinced you get about what you pay for [average $$$$ per unit; can't compare some guy's lucky buy to anothers retail buy] in ZTRs. So, the 3K CC [EZT, lighter frame; interesting engine choice this year though!] I don't see up to your task; perhaps the $3.6 or 4K CC ZForce [IZT.....] would do. I know Dixon has some similar built and priced; that Swisher is likely around the same class too. /forums/images/graemlins/crazy.gif
Good Luck! /forums/images/graemlins/smile.gif
   / Looking for Zero Turn-Swisher? #3
I have alot of left over zero turn from last year (still brand new with warranties)
Where are you located?
2020 EZ-GO Elite RXV Electric Golf Cart (A50324)
2020 EZ-GO Elite...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2001 Sterling L7500 Series VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A50323)
2001 Sterling...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
