Looking for Yanmar YM165D hydraulic parts Help please!
   / Looking for Yanmar YM165D hydraulic parts Help please! #1
Bazman72
Langley BC Canada
Yanmar YM165D
My Yanmar YM165D three point hitch doesn't lift. My mechanic friend diagnosed that I need a new plug and spring (items #19 & 21 on attached image from the Yanmar parts manual). Neither seem to be available in N. America. Hoye Tractor says they are not made any more, although the spring was in their online catalogue until recently. Any ideas to source these parts?
Part numbers (from Yanmar parts manual) are:
194200-46450 plug
194200-46420 spring
Or any idea on the specs of the spring? I think I might be able to improvise with the plug but will definitely need a spring.
   / Looking for Yanmar YM165D hydraulic parts Help please! #2
Is your old plug and spring completely missing? Those seem like they would be pretty unusual parts to have fail. If the spring is just broken then you might still be able to measure it to find a suitable replacement. I think that is the safety valve so if the lift was raised with a heavy mower, for example, and you hit a big bump or something it would drop the implement instead of breaking something. I should have that complete head assembly used if it comes down to it but I could not part it out for those two pieces.
Hi Aaron, I tried to order the parts from Hoye but couldn't. I did order everything else I needed.
The spring is completely missing and the plug has been replaced (previous owner) with an improvised one. Could you measure the spring and maybe attach a photo? Thanks!
   / Looking for Yanmar YM165D hydraulic parts Help please! #4
They are all still in tractors but I will try to get one out tomorrow and get you a picture & measurements.
   / Looking for Yanmar YM165D hydraulic parts Help please! #5
Here are the dimensions of the spring. It takes about 10lbs to compress about 0.25".
Thanks Aaron! Much appreciated. Now I just have to find one.
   / Looking for Yanmar YM165D hydraulic parts Help please! #7
Harbor Freight has spring assortment boxes pretty cheap. No idea whether one might match.
   / Looking for Yanmar YM165D hydraulic parts Help please! #8
This guy on Craigslist might part out that assembly for the spring and plug.
portland for sale - craigslist
That's where I bought the replacement YM240 axle housing. Good service.
I think he has more salvage tractors than just these. His previous CL ads showed a long line of tractor corpses.
   / Looking for Yanmar YM165D hydraulic parts Help please! #9
A spring is a spring.
If it fits your good to go, if too soft add shims.
   / Looking for Yanmar YM165D hydraulic parts Help please! #10
Well, a spring at the same length and diameter is close, but not the same. Thickness and spring hardness are also items of interest.
At a yard sale last year, I picked up a box of NEW trampoline springs for only $1. On the farm, something can use a spring usually.
And Winston, that spring kit from Harbor Freight has bailed me out a few times. Once on the rototiller and again on the B+S Lawnboy mower recently.
The tiller took the big one and the B+S needed one for the carb.
Landscape Truck with Hydraulic Dump Body (A50120)
Landscape Truck...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2009 Champion C80 B Motor Grader (A50322)
2009 Champion C80...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
