Looking for user experience / info with the Deere 5205
   / Looking for user experience / info with the Deere 5205 #11
Having starting problems with my 5205, seems cold sensitive
   / Looking for user experience / info with the Deere 5205 #12
I suggest that you start a new thread, along with providing more detail. ie cranks slow, you are using the - Cold Weather Starting Procedure Using Intake Air Heater System-If Equipped - Here is the operators manual.
http://manuals.deere.com/omview/OMRE72817_19/?tM=FR
May or may not help, but look at what I said in thread #2 and the persons response in thread #4
http://www.tractorbynet.com/forums/parts-repairs/347785-erratic-temperature-gauge-jd-5105-a.html
We have the same engine. Since I started using JD fuel additive and having both the gear and range in neutral my tractor starts easier.
   / Looking for user experience / info with the Deere 5205 #13
I bought a 5205 4wd with loader new in 2006. Traded it in with 800 hours on it, only thing I did other than routine maintenance was replace the rubber fuel lines and the spring on the clutch pedal broke. It was the perfect size tractor for me and had plenty of power and was reliable. I wish I had kept it instead of the new E series.
   / Looking for user experience / info with the Deere 5205 #14
I've used my 5205 for about ten years on ranch work.
I use it to load hay, disk, drill and shred with fine success. It is mfwd with a loader.
Also, use a Beltec to dig post holes.
Couldn't be happier.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
DEUTZ MARATHON...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
