Looking for suggestions
/ Looking for suggestions #1
Rfisher7381
South West Michigan
Kubota BX2360
Have a 2011 BX2360. Shortly after I got it I dropped the plastic piece from the fuel can into the fuel tank. Have been unable to fish it out. Until yesterday it wasn't causing a problem. Now the BX will start and run ok but then suddenly nearly stales out. Both fuel filters were changed last fall. I checked all fluid levels and all is right on the mark. I have a tool with a flexible shaft and prongs that extend out that I have tried grabbing onto the plastic but no luck. I cannot see the plastic. I think it has moved into a position that is restricting fuel flow. Does anyone have ideas or suggestions on getting the plastic out without having to remove the tank. Thanks.
/ Looking for suggestions #2
Maybe you could borrow a flexible fiber optic bore scope from someone. Make sure diesel won't destroy it, of course. Good luck in retrieving it. Or, drain the tank and rig up a suction device (don't want to blow up a vacuum- heard too many stories about guys sucking pull lines thru plastic conduit and exploding vacuums from the glue fumes still left over) to get it out.
/ Looking for suggestions #3
How I got bugs out of my tank was to back left side tire up a dirt pile. Took another tractor lifted the front up high, Drain the tank and it well be right in the corner of the tank, get someone with a small hand to get it out.
/ Looking for suggestions #5
I asked my local K. dealer about the possibility of a plastic cap interfering with the fuel flow. The agent agreed that since the fuel is injected by an electric pump, there is a concentrated flow of fuel exiting around the fuel outlet and that yes, a plastic cap could hinder fuel flow now and then as the cap moves around in the tank. His solution to the problem was exactly what Leejohn stated: that is positioning the tractor so that the plastic piece gravitates to the corner of the tank where it can be retrieved. I suggest that you drain the tank in that position by siphon which might cause a slight flow in the fuel to bring the offending object down to the tank opening. I might add that if you do drain the tank, you could then set up a fuel hose to return the fuel to the tank via a long hose which extends to the further end of the tank, which would create a current of fuel which could help to move the plastic piece.
My dad joked that he intended to write a book entitled "Raising Children for Fun and Profit" but I don't think he imagined a 5 year old with a glove reaching into a fuel tank for a plastic cap! Let us know how you make out with your problem. I can see it happening to me, maybe not the plastic cap but certainly with wood chips from the chain saw.
WESTFIELD 15' HYD AUGER (A63291)
WESTFIELD 15' HYD...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
PORTABLE OFFICE TRAILER (A63291)
PORTABLE OFFICE...
Takeuchi TB225 (A62177)
Takeuchi TB225...
(APPROX. 9) ROLLS OF WRAP (A63291)
(APPROX. 9) ROLLS...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
