Looking for source for seals
   / Looking for source for seals #1
JoelD
Veteran Member
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Hi all,
I find myself looking for various seals for various applications. Other than the manufacturer of the item being fixed (sometime item is so old they don't carry parts anymore), do you have any suggestions as to where I can find seals? Typically shaft seals, for things like gearboxes with shafts that protrude out or the like.
I'm guessing there are sources out there, just not sure where to look.
Thank you,
Joel
   / Looking for source for seals #2
If you have the numbers off the old seals a bearing supply or NAPA can usually cross them to a replacement.
Ken
   / Looking for source for seals #3
seals.. mmmm sharks love seals. ;)
most seals can be matched generically knowing lip style, ID, OD and thickness, at a reputable bearing supply house. "possibly' even at a napa.. but I wouldn't lay any bets on them anymore.. :)
   / Looking for source for seals #4
Motion Industries is a fairly large supply house that carries bearings, seals, belts, etc.. Not sure if they offices in your area or not.
   / Looking for source for seals #5
Anytime I deal with bearings and/or Seals, I try to do it by part # or by size/type.
Timken/national and SKF/cr both have good cross-reference sites as well as a search-by-size feature where you input the bore diameter, shaft diameter and seal thickness.
However you go about it thoguh, get a part number. Once you have that you are set. Most auto parts stores like napa, autozone, oriley, advance, etc can search by that PN. (or you can do it on their website).
Other times, when I needed a seal for my ford BH, I got the national PN. Ford dealer didnt have any. Parts stores didnt have any. BUT, I was also able to cross that ober (through timkens site) to a JD number. But the deere dealer didnt have any either so..... But the point was, if they had them, I could have bought parts at the deere dealer for my ford backhoe IF the had them.
   / Looking for source for seals #6
PS:
Here is SKF/CR website that is good for searching by size.
SKF | Online Catalog | Handbook of Seals (457010) | Parts Lookup
This shows some of the lip types/styles that go with the size lookup http://www.skf.com/files/774717.pdf
Here is the timken cross-reference pdf. (ctrl + F is your friend when using this) http://www.timken.com/de-de/products/Documents/Timken_Seal_Interchange_and_Cross_Reference_Guide.pdf
Also, napaonline.com is pretty good at interchanging when you have an OEM number, like for a truck or tractor. "their" number I believe is a national number.
Thank you very much guys, I did not even think of the seal's (non-swimming and nose-balancing type) part number. I should've thought of that as I did that when doing wheel bearings for an old trailer. All the links are also greatly appreciated. I need to pull the fan off of the blower as the imediate need is for a seal to the shaft running the shaft that runs the chain drive to the auger on my snow blower. I just fitted to my tractor, built up a chute turning handle set up and then went to change the gearbox oil and there was none, filled and it all came out through the shaft seal. Thank goodness I caught early as the machine runs smooth. I am not looking forward to trying to get the fan off, I've had bad experiences with that in the past.
Joel
   / Looking for source for seals #9
Check yor old seals for numbers also as most sae seals will use a part # and metric seals will have the dimensions imprinted on them. (ex. 40x52x8 =id x od x thickness in milimeters)
   / Looking for source for seals #10
you can also get seals by ID/OD/thickness for most applications
   / Looking for source for seals #11
I purchased needed seals from this company:
SKF, Bearings, Seals, Mechatronics & Lubrication | E.B. Atmus Co., Inc.
Their prices with shipping were better than I could get locally.
I also used some of the suggested research sites listed previously. I had difficulties because the seals were old and the numbers didn't cross refrence to anything newer. In addition, the repair was made with whatever was in the shop (explains the RTV :eek:) so after an exaustive search, I still ordered the wrong ones!!!! :confused3:
Finally got the right ones-
:2cents:
   / Looking for source for seals #12
I've found this place to be really reasonable on USA bearings, and seals. JBR 17 LLC, You will need the bearing/seal number to search, and check the price. The bad thing is, if you need it in a hurry, it takes about a week for them to get them to me.
If it's something I know I will need to do maintainance on at a later date, I will cross the part number, compare prices, and order so they will be here when I have time to do the job.
All seals so far have been USA CRC seals, and bearings, USA Timken. And most of their bearings are offered with the cup, usually for less then Motion Industries wants for just the bearing. That really helps when doing one of my 5 trailers, with multiple axles...
   / Looking for source for seals #13
If you have a local bearing supply house, they will also have all the shaft seals, or can order them in. If you are talking online, then any google search will find you a million places that sell bearings and seals.
   / Looking for source for seals #15
not for long anyway!
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2016 VERMEER PD10 PILE DRIVER (A60429)
2016 VERMEER PD10...
