Looking for Replacment Relay
/ Looking for Replacment Relay #1
ktate2002
south Louisiana
Kubota L305DT
I posted about one week ago that the fusible link in the starter circuit had burned. The starter/solenoid passed the test at the local electrical shop, so I started looking elsewhere for a problem. I pulled a relay apart (it does not show up on my wiring diagram) because 2 of the 3 wires going to the relay become hot when I turn the IGN switch to ON. The component that looks like a spool of fine cooper wire is no longer soldered to the circuit board. Does anyone know where I might find this relay? Is there a replacement part? It goes on a 1985 Kubota L305DT. Circuit board has the number A6165A on it. The number on the copper spool is MR31 and the local parts house tells me that crosses to a Borg Warner R373, but the photograph show the BW relay to be a four pin. My relay is three pin. I haven't called a Kubota dealer but I guess that's next. Thanks.
http://community.webshots.com/myphotos?action=showPhoto&albumID=527379156&photoID=2131067420063427796&security=vWLCtt
Takes a farmer to offer a solution. In this case, my farmer friend knows a technician that repairs printed circuit boards used in medical equipment. He'll put it in the hands of the tech tomorrow morning. Hope he can work a miracle on this.
/ Looking for Replacment Relay #5
...having same problem finding this same relay, years later. I wonder how you ever made out with getting yours repaired, or finding another one?
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
