Looking for pole barn insulation advice
   / Looking for pole barn insulation advice #1
zmansmac
Arcadia Township, Michigan
Kubota B7500
I moved into my retirement home last year and now have a little larger pole barn than the last home. The barn is a standard 30 x 40 x 12 with steel sides with asphalt shingles. There is a large door at both ends and only one service door. I am a hobbyist wood and metal worker and my original intent was to use the whole barn for my new shop. I also needed some room for garden equipment and such and my plan was to build a small lean to shed off the back. But, unfortunately, local ordinances require permits for that but not for a stand alone shed. So to save a little money I decided to shrink my shop area a little. I built a wall inside at the second last 6 x 6's which gives me an 8 x 30 area for a shed. The wall I built is 6 inches thick, and like the other sides in the workshop area are already insulated with fiberglass batting. For the ceiling I have 1/4 inch plywood that will be nailed to the underside of the truss bottoms and then I intend to blow 10 - 12 inches of cellulose in. The wall I built only goes up to the bottom of that truss and above that I was only going to put some thin plywood about 2 feet up to retain the cellulose in the shop ceiling area. There is about a one foot overhang on the 40 foot sides of the barn with a fully vented soffit. Now my question is should I completely cover that truss above the wall to isolate the ceiling air space over the shop area from the shed area, or does it make any difference if I don't.
   / Looking for pole barn insulation advice #2
I don't think it makes any difference if you cover it or not. Also, make sure you use a vapor barrier between the plywood ceiling and the insulation.
Thank you both for the quick reply and backing up my theory. Thanks for the advice DuckSlayer; I will use a vapor barrier as you suggest. And truckdiagnostics, I didn't go into all the detail but I have already stapled up the styrofoam vent panels between all the trusses in the shop area.
2019 Chevrolet Express 2500 Cargo Van (A55788)
2019 Chevrolet...
2844 (A54757)
2844 (A54757)
Two Pairs of 8ft Fork Extensions (A55787)
Two Pairs of 8ft...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A55787)
2018 Bobcat T590...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
