Looking for parts for TX1500F
   / Looking for parts for TX1500F #1
Sideways
Southern Maryland
I am looking for the hydraulic lift parts for the 3 pt hitch lift system on my Iseki TX1500F
These part numbers are out of my manual but I have been told they are Bolens part numbers
1871790-rod
1871791-pin rod
1871783-crank lift
1871789-piston
1871447-back up ring (o-ring)
1871446-o-ring (p-50a)
1860727-o-ring (g-55)
1860931-o-ring (p-12)
I would also consider a used assy or parts tractor as well.
   / Looking for parts for TX1500F #2
Sir,if you go to this website (Tractorclutchesrus@yahoo.com). HE Ploblem can help you.he sell alot on e bay but he also has a number you could call about parts to.
   / Looking for parts for TX1500F #3
We have the used parts pulled & will ship when we get the new parts.
Len, we were able to mill the oversized piston down to fit the bore.
The 3pt hitch works like a charm.
My neighbor and I pulled the front differential out from underneath the tractor, then pulled the frame so we had access to the tap the bolt holes in the motor since the previous owner stripped them out when the mounted the FEL mount.
Found the splines were stripped off the frt pinion and they had drilled a hole and pinned the yoke to the pinion shaft, no wonder the tractor stays in 4 wheel drive all the time! :(
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
