Looking for on line parts supplier.
   / Looking for on line parts supplier. #1
239Design
Wapwallopen PA
Mahindra Max28xl
I have search the net for the last two hrs. looking for the boot that goes over the FEL lever. The one on my tractor looks like is sun rotted. The service part # from what i can tell is 230790-3K, I'm not sure if its a big deal but it has to be there for a reason. Thanks
   / Looking for on line parts supplier. #2
My loader (manual operated hydraulics) uses a swivel arrangement so one lever works both the lift and the bucket. When I bought the tractor used, one of the swivels was rusted clean through. The salesman thought the boot must have trapped water causing the rust. He got me a new swivel as part of the deal. I never replaced the boot and probably won't. If your tractor has an electronic joy stick you might need a boot more than I do.
I see the valve is a nimco cv112 so I am going to search that tomorrow. Thanks
   / Looking for on line parts supplier. #4
I searched for the same part a while back, ended up going to Autozone and buying a cv joint boot. With the help of a couple of zip ties it works and looks just fine.
Thanks! I will give that a try.
   / Looking for on line parts supplier. #6
Give Surplus Center a call. They did not have the boot for my valve listed on their web site, but they had several in stock.
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
