Looking for new FEL control valve
   / Looking for new FEL control valve #1
NewClimber
Bronze Member
Kalama, Washington
B7100D
I have a B7100, with a B219 FEL. I am looking for a new control valve and wanted to ask if this would do?
Directional Control Valve | Agri Supply
http://www.agrisupply.com/images/xl/82587.jpg
I like the stick kind where I currently have the one with two levers of which the float does not work. I attempted to take it apart using the many insturctions that I read here, but it is so rusted, I am in need of a new control valve....just not sure what will work. If it is not a direct bolt on, that is OK, just want to make sure everything else will work.
Thank you for the help
   / Looking for new FEL control valve #2
You want to match the flow and pressure settings of the old and new valve. Also figure out if old valve is open or closed center and match the new one. Why don't you call a place like Surplus Center, they'll help you match the right valve and their prices are good.
   / Looking for new FEL control valve #3
You don't want that valve. Look for something smaller, like a 10 gpm valve and look for one with O ring ports, not pipe thread. Pipe thread is much more difficult to work with and will always have leaks somewhere. Your present valve is most likely O ring ports. You can get a joystick valve from Bailey Hyd. for about the same price that will suit your needs far better than the one you mentioned.
2007 50FT 3 CAR HAULER TRAILER (A53426)
2007 50FT 3 CAR...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
ROLLER DOLLY (A53843)
2016 JOHN DEERE 8245R LOT NUMBER 168 (A53084)
2016 JOHN DEERE...
ATTENTION PLEASE READ (A50123)
ATTENTION PLEASE...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
