Looking for natural cooling ideas
/ Looking for natural cooling ideas #21
Strength isn't the issue and 2x6 walls are just fine for strength. I am looking for the thermal mass of concrete along with a place to run my wires. Lots and lots of commercial buildings are constructed with block walls in washington so I know there isn't a seismic issue. I wonder how tilt up concrete wall construction is in residential sites. That is the current craze in commercial construction.
HVAC ducts within the floor slab? I would have never thought it. I need to also consider non-ducted heating such as radiant slab heat. I plan to use a woodstove for heat. Perhaps HVAC is not necessary with adequate thermal mass? Our climate is very moderate most days even though we break 90 today and 95 tomorrow the ground temp is nice and cool and we dip into the 50s most summer nights. Whoa, no heater vents.
/ Looking for natural cooling ideas #22
"Perhaps HVAC is not necessary with adequate thermal mass? "
Just be sure that you have a "primary" heat source OTHER than a woodstove. No one will monitor which you primarily use but getting insurance on a home with woodstove heat is expensive and not readily available.
Phil
/ Looking for natural cooling ideas #23
True, IFCs are tight on air leaks, that can be done with and without concrete.
You don't need IFCs to glue Foam on to poured concrete walls.
Also, you can't play the card "good insulation and thermal mass at the same time with IFCs". The Thermal mass IS INSULATED from it's source of heat gain/loss outside and location of deposit inside if it is so well insulated. Choose one card or the other.
Point is, choose where you want that insulation wisely.
The western adobe has no isulation, just massive amount of thermal mass, 2-3' of earth. You can open the door for one hour and let all the heat in of the mid day. When you close the door, the heat will be absorbed in the the walls. If those same 2-3' adobe walls had the same fine foam insulation of IFCs inside, well it would just be hot and steamy. The less foam you had the quicker the room would return to pre door open temp. Another example; an empty frige at 45 deg will heat up once the door is opened in short order. The same frige filled with water jugs will maintain the 45 deg starting temp for quite some time.
The number one advantage of IFC was "home owners can stack foam legos and fill them will concrete and think they are saving money"
Sorry for my rant, but I'm just not sold on them
/ Looking for natural cooling ideas #24
Regarding the wood stove and getting insurance. I'm sure it depends on your location but we got insurance on our house with the stove. Did it raise a flag? Yes. But the cost of insurance for the new house which is twice the size of our old house and worth far more, was about the same as the old. We eventually went with Farm Bureau insurance and drastically cut the cost of insurance for the same coverage.
Insurance and mass. Based on the questions asked by the insurance company the one thing that helped us with the insurance and the wood stove was the finished concrete floor. Its hard for the floor to catch on fire. :D Course the insurance company did not have a check box for Finished Concrete Floor so we had to use tile instead. :) Since we don't have carpet, can't stand the stuff, the slab acts as a huge thermal mass. It works. The wood stove sits on a brick and granite hearth. The brick is doubled so that the hearth is seen in the master bedroom and the study so that the heat from the stove can radiate directly into those rooms. The hearth is a fair amount of mass in the house.
We went through the idea of ICFs but we could not justify the cost, we kept bumping into a cost of an extra 5% over stick construction. Plus we knew we where putting in huge area's of wndows. Why have this expensive wall that is supposed to be energy efficient but then punch 8'x6' holes into it? :eek: We wanted the ICFs to protect the house against falling trees but in the end we went with 2x6 walls with the 1 inch foam. This got us about the same R value as ICFs and some strength but at less cost. Given the window holes maybe we should have just kept 2x4 walls but I think we made the right decision.
You can add mass to the house without having to involve the exterior walls. One of our earlier designs had a sun space that ran the length of the southern side of the house. We wanted an eight foot "room" for solar gain. The idea was to grow some plants as well has the passive solar design. The "room" would have had extra mass built into the interior wall to hold the solar heat. But that idea was just to expensive. There is a NC Solar Center at NCSU. We went there in December a few years ago after we had days of temps dropping into the teens and 20's overnight and not getting out of the 30s. The NC Solar Center house had a bunch of passive and active technique/technologies. It is bermed into a hill for instance so the first floor has roughly half the house covered by grade. The house was so hot inside we had to take off our coats and sweaters. The porch that was enclosed by glass was 90 degrees while the outside temp was in the 20/30s. The downstairs was built out of CMUs if I remember correctly. The upstairs was stick built.
The Enertia homes I mentioned in an earlier post use the 6x6s and other large diminsion lumber as thermal mass in the interior.
Later,
Dan
/ Looking for natural cooling ideas #25
Stumpfield - You have many good ideas. The 4 that come to my mind are:(1) ICF construction from base to roof..available in different wall thicknesses, (2) the porch overhangs on the sunniest sides, (3) air flow in attic/crawl space, &(4) key placement of trees and bushes. The bushes are designed to keep the ground from heating up and warming the structure.
/ Looking for natural cooling ideas #26
haloguy mentioned one good thing was landscaping, thermal mass needs to be effective, having a big ole hot stone in the sun will soak up a lOT of heat and let it go through the night, same with a house, this is good in winter, bad in summer, so you need to plant fast growing shading plants that drop their leaves in winter, shades the home in summer and exposes it to the sun in winter. other things are that using light water spray to feed these plants helps inhot summer and none is needed in winter... solar heating is good solar cooling can also be effective. useing the sun to move the air past water cooled medias can caluse a good temp drop which can be moved into the home...
anyhow lots of good info here and else where on the net.
markM
/ Looking for natural cooling ideas #27
ICF construction is a proven method with thousands of houses all
over the US now. There are over 80 US vendors of ICFs from what I hear.
The advantages are clear and proven. In my own 2100 sf house I
have the smallest forced-air furnace (40KBTU) and a 34KBTU wood
stove, either of which can easily heat the whole house by itself. The
thermal mass, strength, and lack of leaks works amazingly well to
save me 50%+ in heating costs vs my old frame house. I eliminated
central AC in my mild climate. THERE is a significant savings right there.
In my DIRECT experience with 2 dozen projects, the main downside to
ICF construction is the difficulty getting contractors to build with it
and engineers to do the calculations. Both trades are extremely
resistant to changes and most benefits to ICF construction go to the
owner, not the builder.
/ Looking for natural cooling ideas #28
dfkrug said:
....the main downside to
You would think that is the way it's supposed to be? ...for the homeowner's benefit. Why are they so "resistant" to that, I wonder?
/ Looking for natural cooling ideas #29
Well when you fixed-bid a project and you are learning a new method,
it is understandable that you are taking risks with how much time/effort the
new method will require. There is an inherent resistance by contractors
or engineers to changing ANYTHING. Historically, there was extreme
resistance to the use of plywood after WW2, ABS plastic drain pipes,
and other materials/methods taken for granted today. The only real
benefit to the builder is a better house, and that only affects the bottom
line in a market where the builder builds on spec and has to market his
house in competition with other conventionally-built houses. Ususally,
ICF houses are custom-built for particular customers who have done
their research and demanded ICF construction.
/ Looking for natural cooling ideas #30
Paddy said:
Thermal mass mainly helps when outside temp swings above and below inside desired temps DAILY. For example, in the MN twin Cities, ave winter temp fluction never get above inside desired temps. Same can be true for FL, hot all 24Hr. In AZ, you get nice temp swings and you can stored the heat of the day for use in the chilly night.
This is very true. We have good thermal mass with our log home. In the summer it can get into the hundred + teens during daytime, yet usually cools off nicely at night. The solar gain from the day re-radiates back outward at night. During this recent heat wave, however, we had a bit of humidity which acted as a thermal blanket at night, which kept the outside temp. in the 80s. Instead of radiating outward, the solar gain all radiated inward all day long. The AC ran 24 hr./day. The logs usually function to save on elec. usage, but for that week and a half, they cost us a bundle. It would have been more efficient to have had a traditionally insulated home then. Thank goodness we are back to normal now.
/ Looking for natural cooling ideas #31
ICF construction is really best for the DIY type. You don't need forms, but Lots of bracing though. They are very pricey for what you get in the end. Simple put, in the end you get poured walls with foam on the outside. You can have conventual walls poured and attach the foam or I've seen methods where the foam is placed in the forms before the pour. Its been a few years but, I have had 10' walls poured for $75 a running foot. 2" blue foam on both sides is $14 a running ft, w/o labor. It might be $20 a runing foot installed either by 'in the form method' or gluing. So we are at $10 a sq ft for 8" poured walls with 2" blue foam in and outside. And you don't have to do the work! Just write the check. The ICFs are about $3.45 a sq ft no labor or concrete/rebar/bracing lumber.
/ Looking for natural cooling ideas #32
Yes, ICF construction is very good for the DIY type. But there are many
contractors around the country who specialize in this type of constructon.
They are very efficient at it and can set, brace, and pour houses in just
a few days. Bracing is required for any kind of concrete walls and there
are there are numerous brands of adjustable braces you can buy or rent
for ICF construction. The contractors who specialize in ICF construction
OWN these reusable steel braces. There are huge labor savings using
ICFs over conventional poured walls. Finally, in terms of cost of ICF
construction vs. wood frame.....that is not a simple calculation. First, the
outside walls (frame) of a house only amount to about 10% of its total
construction cost. You may pay somewhat more for ICF vs. 2x6 for this
part, depending on how experienced your builder is. 2x6 construction is
getting close in cost, however, as you take into acct all of the steel
ties and moment frames now reqd by newer building codes, esp in seismic
and high wind areas. Then there is the energy savings for the owner to
acct for.
/ Looking for natural cooling ideas #33
"There are huge labor savings using
ICFs over conventional poured walls."
Not sure where the huge savings comes from. Setting up forms goes quick. But in the end, how much does it cost for a ICF wall per running ft? I don't really care how much time a contractor saves, just price in the end.
I'm sold on concrete. I have used my last 2x6. My next home will not only have Concrete walls on the ground floor, but concrete second level floors, second story walls and a concrete flat roof. For most of the walls, I will go for a poured wall with the foam on the inside. This is for fire protection and true effective thermal mass. Thermal mass does much less good if insolated between foam. I will run ele thru the foam via conduit. I believe Stress skin panels are wired this way.
I'm glad to see the intrest in concrete construction finally hit the US. Now all we need to do is tweek the designs a bit and have more skilled masonary designer and labor. there some out there though.
/ Looking for natural cooling ideas #34
I just wanted to post a little help to this summer / winter designing help ideas can be had from a pretty good mag, Mother Earth News. it is a 6 book/yr mag. lots of good articals about many homesteading green energy renuable info. farming ips ect too. I'm not yet a subscriber but have been reading it on/off for a few weeks due to getting some old ones from a coworker who has had a long term suscription. he said they used to have a hole lot more "Do-It-Yourself" articals, plans in there the one I was just reading last night had some really good solar food drier plans in it. :) no I'm not affiliated with them, just think they have a good bit of actually USABLE information in there ...
http://www.motherearthnews.com/
Mark M
heck they had a 10.00 (pay now online link/url on the web site so I signed up for myslelf ;D
/ Looking for natural cooling ideas #35
dfkrug makes a very important point on cost and that is an experienced ICF building design and construction crew make fewer mistakes, move quickly, and know were additional attention is needed during the build phase and can be competitive on cost. One of the common early mistakes by DIYers is insufficient attention to vertical and horizontal straightness and foundation level tolerances. My spouse and I are in the process of selecting the ICF manufacturer which will then be followed by ICF experienced contractor and architect/designer. There were many important features in ICF construction but two were that we live in a high wind area which requires hurricane force stability and secondly with significant seasonal weather changes we require a stable exterior for masonry applications e.g. Grailcoat, stucco, etc. I only wish there were more ICF experienced tradesmen in the northeastern US.....Cheers.
/ Looking for natural cooling ideas #36
Haoleguy said:
. One of the common early mistakes by DIYers is insufficient attention to vertical and horizontal straightness and foundation level tolerances. My spouse and I are in the process of selecting the ICF manufacturer which will then be followed by ICF experienced contractor and architect/designer. .
I have found ICF installation mistakes made by both DIYers and contractors.
If I can generalize, at least the DIY types ask questions. I have found that
contractors I am training to do a first time install often insist on doing things
their own way. Furthermore, if they have had some exposure to another
brand of ICFs, they may resist or ignore any installation directions. Different
brands of ICFs have different installation and pouring requirements!
In the choice of an ICF, the most important consideration is local support of
the installer from a factory-trained distributor.
There is a Concrete Construction thread now for this subject.
2004 John Deere 4710 Sprayer (A63688)
2004 John Deere...
John Deere 4840 Tractor (A66285)
John Deere 4840...
Woods BW180HD Batwing Mower (A66285)
Woods BW180HD...
Yale 5K Forklift (A63688)
Yale 5K Forklift...
John Deere Z994R (A60462)
John Deere Z994R...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
