Looking for Long Backhoe Parts
   / Looking for Long Backhoe Parts #1
Long 5n1 Backhoe
milford, nj
Long 5n1 Backhoe
Have a Long 5n1 Backhoe that is a lot of fun to run, but I'm currently out of commission due to needing a part for the backhoe valve assembly, or a complete valve assembly if I can't find the part for the assembly.
With the manufacturer being long out of business, I have made a lot of calls trying to find the part and have come up empty. I am hoping someone on this forum might know where the part might be found.
I would greatly appreciate any help, thoughts, ideas for getting my machine back up and running.
Part Numbers that would work would be: 732667, 809559, 736816, 745229, 745227, 742836.
Many thanks.
   / Looking for Long Backhoe Parts #2
Not sure what part of the backhoe you need. If it a cylinder or valve that you need, pull off what you have and take it to a hyd. repair shop. Tell them what it came off of and they will take it apart and provide you with what is needed or give you a estimate. Do not be shy tell them what your problem is. I thank you for posting as I did not know that Long was no more. I see them at auctions and will keep this in mind.
   / Looking for Long Backhoe Parts #3
I have a long 119a backhoe. I haven't needed parts yet, but I have only used it twice so far. the first time I found out I needed to rebuild all the cylinders, so I did. the second time I found a leak in a hose that I have yet to replace because the equipment is 30 minutes away. I suspect with all the other issues I have had, I will probably end up pulling the valve assembly and needing to rebuild it as well.
Do you have a physical part of the valve assembly that's broke beyond repair, or is it just not functioning properly? it really could just be worn out and needs to be rebuilt.
   / Looking for Long Backhoe Parts #4
Indygunworks, Hi. Know it was a while back but you mentioned that you had rebuilt the cylinders of your 119 a long 3pt backhoe. I assume this is same as 1199a long backhoe. Where did you source your parts for repack of cylinders. One of my swing cylinders has lost it and I need to rebuild. You can post here or my email is ttips@hotmail.com.
Tks. ttips in Alexandria In.
   / Looking for Long Backhoe Parts #5
A GOOD hydraulics/cylinder shop can source generic parts.
I replaced tilt cylinder cups on an old Clark forklift and bought blank 4" cups and punched bolt holes in them to fit.
   / Looking for Long Backhoe Parts #6
i have a long 3pt backhoe as well did you have a list of the seals because that is what Im rebuilding now. with the seal numbers part numbers that is, it cost half the price to find with out it cost me double.
im rebuilding now is the seals with numbers its half the price with out they want 65 a cylynder.
   / Looking for Long Backhoe Parts #7
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
1996 JCB 506B Telehandler (A55218)
1996 JCB 506B...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
