Grapple Looking for information on a block and tackle
   / Looking for information on a block and tackle #1
schriftleiter
I have a neighbor who pulled my tractor out of a bog using a block and tackle. The diameter of the pulleys are about 12 inches and the cable about 1 inch thick. Does anybody know where these might be sold?
   / Looking for information on a block and tackle #2
   / Looking for information on a block and tackle #3
you can probably buy a cheap 8000 electric winch for the price of a good Crosby block and tackle or chain fall. It would be a lot handier for other jobs as well...
   / Looking for information on a block and tackle #4
Or one of these:
8000 lb. Cable Winch Puller
Ours has really been helpful for us in numerous situations...
Then you just need the auxiliary cables, straps, or chains to make the hook-up between whatever you're pulling and anchor points.
   / Looking for information on a block and tackle #5
I have a Chance hoist that I put 25' of load chain on about forty years ago. Only 1 Ton, but there have been a few times when its saved the bacon, despite currently having 3- 8000lb winches to choose from, along with another four smaller ones.
   / Looking for information on a block and tackle #6
A Hy-Lift Jack and a chain will also work to get you unstuck.
   / Looking for information on a block and tackle #7
And can lift your car, truck or tractor too- if the ground is firm enough to hold it... This can be helpful at times to put materials underneath the tires to add traction.
Also it can be less of a PITA to work with than the cable puller, though it moves less each time before resetting.
Unfortunately I never think of it for that....
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
PALLET OF (2) ELECTRIC CONDUIT BENDERS (A55745)
PALLET OF (2)...
2020 FORD F-350 FLATBED DUALLY (A55745)
2020 FORD F-350...
2003 Chevrolet 1500 Silverado Crew Cab Pick-up Truck (A55852)
2003 Chevrolet...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55314)
2024 BCL...
