Looking for hydraulic bucket valves replacement for 3840 Montana tractor.
   / Looking for hydraulic bucket valves replacement for 3840 Montana tractor. #1
Anthonytati
Montana 3840
I’m Looking For This Part. Not Good With Computers So I Have no Choice But To Post pictures.
This is on A Montana Tractor 3840
Part # Seems to be A Problem. Can Someone Help.
   / Looking for hydraulic bucket valves replacement for 3840 Montana tractor. #3
Finding exact replacement is going to be tricky. The OEM manufacturers usually make those things under contract to the tractor company (Montana in this case, which was built by what is now LS) and they won’t sell direct.
You can either try a larger LS dealer and see if they can find the direct replacement, or you can install a universal joystick valve assembly like this one at Surplus Center:
https://www.surpluscenter.com/Bran...ontrol-Valve-w-Float-Chief-220957-9-12475.axd
   / Looking for hydraulic bucket valves replacement for 3840 Montana tractor. #4
I wonder why do you want to replace the valve. Valves usually don't go bad that often.
What's wrong with it?
3Lfarms has a good suggestion. Surpluscenter does have a couple valves available that will work just fine.
   / Looking for hydraulic bucket valves replacement for 3840 Montana tractor. #5
Unless something is scored, you most likely can just replace some seals or Orings to rebuild it. If you aren't comfortable doing it, I'm sure a good hydraulic shop would do it.
2023 JOHN DEERE 8R370 LOT IDENTIFIER 204 (A53084)
2023 JOHN DEERE...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
VULCAN STAINLESS STEEL STEAMER (A51248)
VULCAN STAINLESS...
