Looking for help with an 855
   / Looking for help with an 855 #1
jaybrad
Central Maine
Massey Ferguson GC 2310TLB
My dad has an older 855 with a little over 1,000 hours on it. Yesterday, while helping him do some yard work, I noticed that it kicks out a black cloud at startup and continues to smoke quite a bit while running; more throtte, more smoke. It also seemed that compared to my little GC2310, the 855 did not have nearly as much power at a comparable RPM.
When I asked him about the smoke, he said it's been like that for quite a while, but since it still starts right up and works OK, the expense of having it serviced by the dealer has caused him to do nothing to identify the problem.
I took off the air filter, which had a lot of dirt in it and thought that maybe a reasonable starting point would be to give it a routine servicing - and then from searching around on TBN, I am also wondering if it also needs a new injector (or 3)?
I don't expect the basic maintenance to change the smoke issue, but I'm pretty sure it's overdue.
The injector thing is where I'm less certain - and even if I'm going in the right direction? Is there a way for a backyard mechanic to identify and change a faulty injector? Are those things expensive - and does this sound like a reasonable path to follow?
Thanks very much,
Jay
   / Looking for help with an 855 #2
Usually black smoke indicates a lack of air - the fuel to air ratio is wrong.
I think you were on the right track with looking at the air filter. If the engine runs without missing/shuddering, I don't think it would be an injector problem. If you are having lack of power, it could be a timing issue.
I would first put in a new set of air filters, and see if that corrects the problem before digging into anything further.
Usually black smoke indicates a lack of air - the fuel to air ratio is wrong. <snip>
Filters? As in plural? I know about the one that sits at the rear of the engine (with the fins on the bottom), but is there another one somewhere?
Is there a good online source for filters (oil, air, fuel, hydraulic) - and a source where I can find the service specs?
Thanks very much,
Jay
   / Looking for help with an 855 #4
Thanks very much,
Jay
According to jdparts.com there is an inner and outer filter on the 855. P/N AM108184 and AM108185. ~$35 each
   / Looking for help with an 855 #5
855 came as both a single element air filter assy, and as a dual filter ( 1 inner safety filter & 1 outer filter) most rear mounted ones were only a single element
p/n AM102746
   / Looking for help with an 855 #6
I took off the air filter, which had a lot of dirt in it....
On the inside or outside of the filter, Jay? On the inside means you
are getting dirt into the engine. Unless you have the dual filter system
mentioned and the dirt has not made it past the innner filter.
Black smoke while running (not at startup and not under sudden heavy
load) can also mean your cylinders are worn and your compression is
down, resulting in incomplete fuel burning. Do you have a lot of
blow-by gas coming out of the crankcase vent?
The dirt was on the outside, which is good.
The smoke seemed rather constant. There is a burst at startup, then it continues at all RPMs. I did not notice a pattern to when it was worse.
I didn't look for (or at) the crankcase vent. Whereabouts is that located (other than on the crankcase :rolleyes:)?
Thanks,
Jay
   / Looking for help with an 855 #8
The vent hose connects to the breather cap on top of the valve cover.
You may have to disconnect the hose. I no longer have my 955
service manual, unfortunately, as I gave it to the guy who bought
my last 955.
   / Looking for help with an 855 #9
I agree with the air filter(s) change. You might also check the hydraulic system. Sometimes if a scv lever sticks or rockshaft linkage gets out of adjustment, it wil cause the engine to run under load making it smoke and lack power. Do the hydraulics heat up quickly?
(still willing to show how much I have to learn) by heating up do you mean literally? Would I need to physically feel the lines to know?
I had a 755 about a decade ago, but my recent tractor experience has been with my M-F 2310, which certainly acts differently (and better) than this 855. So I don't really have a good point of reference for how the hydraulics are supposed to work on this machine.
I really appreciate these tips and will make a note of them for my to do list next weekend.
In the meantime, I think I'll be picking up a few filters, some engine oil, and some hydraulic fluid - since I don't think this machine has been serviced in a rather long time - and then give it a good once over. And I'll try not to make it worse in the process. :rolleyes:
Thanks for any and all suggestions.
Jay
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
