looking for help in Cutting prairie grass
   / looking for help in Cutting prairie grass #1
Poppleriver
Northern Mn
Bobcat T770 Skidsteer, JD 3039r with 160 loader
All,
I have a 3039r JD (30 hp) with a LX5 brush hog and am trying to cut 30 plus acres of seeded prairie grass. It's a terribly slow process. Grass is kept laying on the fields and not picked up or bundled. Is there a better way to cut these fields rather than use a brush hog. My JD dealer says the tractor is maxed out and cannot utilize a larger brush hog. Looking for suggestions. Thank you.
Popple River's Bernie
   / looking for help in Cutting prairie grass #2
Buy a 6 foot drum mower. Tractor tools direct has pretty good deals and 30 hp will run a 6 foot easily but they say 40 hp. I used to run one behind a 1963 ford super dexta 32 hp and never even felt like I had it in a strain. You want a drum mower not a disk mower and there is a huge difference in the to designs.
   / looking for help in Cutting prairie grass #3
Unless it is god awful thick you should be able to run 3rd or 4th gear pretty easy because your just cutting the grass once rather than mulching it up.
   / looking for help in Cutting prairie grass #4
Ar you just wanting to cut it, or trying to hay> If possibly hay the drum mower would work. However if you just want to cut and leave grass a flail mower would be better. Iowa Farm Equipment carry's a wide selection and others can be found with an online search. Be careful of the china knock offs. A flail mower would mulch the grass and not leave clumps.
There is also a very long thread here on flail mowers. Its like a bible of information.
Hope this helps
   / looking for help in Cutting prairie grass #5
Maybe think about a sickle bar mower? But it must have very sharp knives and be tight.
Thanks for the input. I'm going to search for a good flail mower. Appreciate everyone's input.
   / looking for help in Cutting prairie grass #7
I'm running a 6' brush hog on 32 hp off my pto. Unless the grass is very thick, and gets hood high or higher, I don't have any problems cutting it. 30 acres is still going to take a long time to cut with a 6' mower.
CATERPILLAR CS54B ROLLER (A52707)
CATERPILLAR CS54B...
1997 Chevrolet C3500 Auto Crane Service Truck (A55852)
1997 Chevrolet...
John Deere 3025E (A53317)
John Deere 3025E...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
